03-14-2012, 06:49 PM | #1 |
Newbie Join Date: Mar 2012 Location: Flushing
| MIP cross pin set screw
So I just bought the MIP CVD kit for my SCX10... here: MIP Spline Center CVD Kit, Axial SCX10 and unless I'm missing something, I didn't receive the shorter of the 2 set screws included with this kit, those that go in the cross pins, here: MIP 3/32 x 5/8 Replacement Cross Pins (4) for 1/8, X-Duty and Monster Truck Kits So uhh yea, I need to know what size/diameter/type of set screw I need. |
03-14-2012, 07:04 PM | #2 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
| Re: MIP cross pin set screw
I can't remember exactly which one is which, but here's the 2 sizes that come in the pack.: 99031 SHSS/ 8-*‐32 X 1/8 Cup Point ( 99032 SHSS/ M4 X 5 Cup Point ( As you can see, one is metric, and one is standard. Check and see which set of allen wrenches fits what you have, and that'll tell you which one you're missing. |
03-14-2012, 07:29 PM | #3 |
Wow, glad somebody knows that. Leave it to MIP to go mixing standard and metric hardware. I hate it when my rigs are half one and half the other. I know the setscrews that retain the MIP's to the axial outputs are 4mm diameter. If your SCX is the newer style your going to want Traxxas through pins for a Revo joint. The new through pin'ed Axial shafts don't have flat spots for the setscrews to bite. |
03-14-2012, 08:01 PM | #4 | |
| Re: MIP cross pin set screw Quote:
03-14-2012, 08:02 PM | #5 | |
03-14-2012, 08:50 PM | #6 |
Traxxas part# 5189 I think, mine were laying around extra from an E-maxx. They are a little long, so I cut about 3mm off of the "pin" portion so it wouldn't stick through the other side. If you wanted to be all OCD on it then you could cut it short enough to just fit through the pinion shaft, and then use the plain 4mm setscrew on the other side. The only rig I have sporting MIP's is the Wraith, it it needed red loc-tite on every threaded surface to stay together. And if your running longer than stock shocks, make sure the MIP's don't bind at full droop. |
03-14-2012, 09:42 PM | #7 | ||
TowerHobbies.com | 5189 Traxxas Screw Pins 4x13mm w/Threadlock (4) Quote:
Lastly, found what I am missing from my MIP kit TowerHobbies.com | 99031 MIP Cup Point 8-32x1/8 ( Too bad Tower doesn't have it, they're within a days shipping time of me. Guess I'll have to contact MIP and see if they'll send me replacements, though I'll have to wait another week because they're in California. /end rant. | ||
03-15-2012, 03:44 PM | #8 |
| Re: MIP cross pin set screw |
03-17-2012, 02:32 PM | #9 |
Under normal use blue is probably all that is required to keep the MIP's together. However, every metal to metal fasteners required red loc tite to stay together on my Wraith. From the lower trans gear screws, to the setscrews in my lockers, to ring gear bolts, to motor mount screws. I'm convinced that the Wraith platform is just hard on parts with it's big tires, extreme steering angle, and in most cases way more than plenty of power. As long as you have good allen drivers taking the Red loctited bolts apart isn't that bad... |
02-26-2015, 03:11 AM | #10 |
Quarry Creeper Join Date: Oct 2012 Location: meriden
Not sure if this is related but I just installed set of mip shafts in my wraith and I stripped the crosspin that attaches the driveshaft to the pinion output on the axle...any way to get crosspin out? I also used blue Lottie like an idiot....
MIP cross pin set screw - Similar Threads | ||||
~TSS~ GIVEAWAY! Ultimate Set Screw 3mm Set! | STANG KILLA SS | General Crawlers | 78 | 09-10-2011 07:40 PM |
Broken Cross Pin on Junfac Shafts? | alexchen86 | Axial AX-10 Scorpion | 4 | 03-09-2010 07:33 AM |
mip cvd replacment pin | BOBO_XLT | Axial AX-10 Scorpion | 20 | 12-02-2008 07:09 PM |
MIP CVD cross pin alternative | pariah | Tamiya TLT Crawlers | 4 | 08-21-2008 10:20 AM |
