Thread: Removing the slop from a Summit trans
Old 03-20-2013, 02:11 PM   #21
MEOW
Natedog's Avatar
Default Re: Removing the slop from a Summit trans
The Rooster, great idea and great write up thanks for sharing! Should definitely be a sticky!
Old 04-11-2013, 03:11 AM   #22
ill be doing this next week when mine gets here
joshjunior is offline   Reply With Quote
Old 04-11-2013, 06:23 AM   #23
Just to clarify, this mod is only good for a car that was modified to use the summit trans but not for an actual summit right?
RcSummitVXL is offline   Reply With Quote
Old 04-11-2013, 07:22 AM   #24
There are some concerns that the smaller tabs would break off if it was done to a Summit. I personally have not tried it, but feel it would hold up just fine. I've been running the mod in my SCX over a year now, have recently converted it to brushless and it still has given me no problems.
TheROOSTER is offline   Reply With Quote
Old 04-19-2013, 02:45 PM   #25
Ok, I haven't done the mod yet but I will post the results if I do it on my summit.
Old 04-24-2014, 02:45 PM   #26
This is one of the little things that bugs me about my Summit. I may have to give it a try and see how long it holds up.
Maybe you could carefully remove the bars between half the small holes, allowing one to keep the larger tabs. There'd be a *little* slop still, but far less than the half turn it currently is. Of course, that'd weaken the gear more.
fryfrog is offline   Reply With Quote
Removing the slop from a Summit trans - Similar Threads
summit trans slop klabeaume Traxxas Crawlers 6 09-09-2011 11:12 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
