03-18-2012, 08:35 PM | #1 |
| OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!!
Would you guys like a near 6" pin style tire? What's your ideal width? Any other ideas...let me know Last edited by crawl-o-matic; 03-18-2012 at 09:11 PM. |
03-18-2012, 08:40 PM | #2 |
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!!
6" is too tall, IMO. Just shy of 5.75" is what I'd prefer....
03-18-2012, 08:46 PM | #3 |
I assume you are talking about a 2.2 comp crawler class? Mounted up and ready to go I would say 5.5"-5.75" tall by 1.75"-2.25" wide. |
03-18-2012, 08:53 PM | #4 |
RCC Addict Join Date: Jan 2010 Location: Lafayette
Big holes need big tires. And noone makes a 6" production tire, so you'd have that segment all to yourself. I say 6" tall x 1.75-2" wide. Nice long contact patch rather than wide. Thin soft sidewalls so the user doesn't have to shave them. Last edited by shelljeep; 03-18-2012 at 08:57 PM. Reason: added detail |
03-18-2012, 09:25 PM | #5 | |
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! Quote:
I say space the pins out a little farther than other pin tires that are out on the market so they'll grab ledges better. 5.75in x 1.9-2.4in wide and web the sidewalls so they arent rolling over on side hills, and that should make it some what easier to tune with a foam too. maybe have some sort of solid lug spaced very sparsely for better digging and grabbing ledges. after this tire is released would you look at maybe a 1.9 comp or scale tire? Last edited by 2500hdon37s; 03-18-2012 at 09:42 PM. | |
03-18-2012, 09:28 PM | #6 | |
Not correcting, just mentioning. Depends on the tire compound used. If it's a really soft compound and alot of space is between lugs, they'll just fold over and won't do their job. | |
03-18-2012, 09:33 PM | #7 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Imo I would prefer a tire around 5.7" tall and 2.15"-2.25" wide when mounted on a 1" wide wheel.
03-18-2012, 09:41 PM | #8 | |
I would also say make the pins a touch taller/ deeper tread than racing style pin tires. (but not too much to where they fold) | |
03-18-2012, 09:45 PM | #9 |
Pebble Pounder Join Date: Feb 2011 Location: kelowna Canada
I say 6" tall x 1.75-2" wide. siffish side walls many lugs for maximum customization in an off set pattern as so .o o o o o o o o o o o o o o o .o o o o o o o |
03-18-2012, 09:49 PM | #10 |
Rock Crawler Join Date: Mar 2011 Location: sebastopol
6'' is deffinatly too tall. I would say 5.5'' to 5.7'' max. Width i like too see under 2'' say 1.75'' on a 1'' wheel.Needs too be light weight,a stock white rover with a little wear weighs about 90.3 grams,my shaved ones 88 grams.The trend these days seems to be shaved sidewalls,so a less aggressive and softer sidewall probably would be the ticket.Softer sidewalls can be tuned with foams.And with the pin design,guys can cut,cut,cut to their hearts content. Thanks Matt for working on a new tire for the comp world.Looking forward too seeing what you come up with. |
03-18-2012, 10:05 PM | #11 | |
For sure, 1.9's are on the table! Quote:
03-18-2012, 10:48 PM | #12 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
I would suggest making the tire a solid 5.5" tall Width 1.75 Pins a little larger around than the tires currently out there. Short lugs, NOT tall Smooth sidewalls. Great compound. You will sell a zillion sets |
03-28-2012, 09:25 PM | #13 |
Quarry Creeper Join Date: Feb 2008 Location: chico
Id would run them. would a dual compound tire be possible. medium side walls with pins spaced out like1/8 " apart. And a super sticky pin compound on top
03-28-2012, 10:25 PM | #14 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
| Re: OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! |
03-29-2012, 06:37 AM | #15 |
IMO, the rubber compound is far more important than the tread pattern. Get the rubber right, and they'll sell.
03-29-2012, 05:48 PM | #16 |
Rock Crawler Join Date: Oct 2011 Location: smithville
I like the taller tire idea, no one makes one that tall, plus the pins I think tend to sit lower than a lugged design just due to the fact that the lugged hold their shape and don't fold down. I hope that made sense, anyway good luck!
03-29-2012, 06:44 PM | #17 |
Rock Crawler Join Date: Nov 2009 Location: poteau
i'm with most people, 5.5 to 5.75 inches tall mounted on a 1 inch wheel. width 2.2 inch or narrower. i like the idea of a webbed sidewall to help sidehill stability, and if you could duplicate the rubber compound of the panther lepoards that would be awesome. as far as pins go, i think shorter would be better than taller, but i would put as many pins on as possible. this would give the end user the ability to cut/trim to personal taste. and for the love of god, make the bead better than the boss claws for mounting!!
03-30-2012, 02:22 AM | #18 |
I think 6" tall and a width of 2" is perfect. Maybe like a medium/soft compound. That way if people want to shave the sidewalls they can and if people dont, the tire will still perform great. My ax is set up for 6" tires so that is the main reason i suggested it |
03-30-2012, 04:32 AM | #19 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
I have a set of custom pin tires that are 5.7 x 2" and it is amazing the difference it makes in ground clearance. I wouldn't go any taller as i think you will be getting to much side wall and it will hurt performance.
03-30-2012, 12:23 PM | #20 |
- 5.8" tall, 2" wide. -Thin, smooth sidewals, but have the very outer edge of pins come around the corner where the sidewall and crown meet, so that there s a little bit of grab when the tire is folding onto it's edge. - Softest compound you can find. - 2 size pins on one tire. Perhaps something like thism byt with square pin shape. O o O o O o O o O o O o O o O o O o O o O o O o O o O o O o O o O o O Last edited by TSK; 03-30-2012 at 12:25 PM. |
OTTSIX Pin Tire INPUT NEEDED!!!!!!!!!!!!!! - Similar Threads | ||||
*******ottsix 2.2 schism tire giveaway***************** | crawl-o-matic | General Crawlers | 187 | 03-11-2012 01:32 AM |
Pin Tire with Comp Tire Sidewall - How To Write up | Kraqa | Tires and Wheels | 16 | 08-27-2010 11:55 PM |
input needed | adamargue | General Crawlers | 7 | 06-10-2010 10:25 AM |
Input needed | wrightcs77 | Minnesota | 9 | 04-27-2009 10:46 AM |
your input needed. | Crawler Noob | Chit Chat | 14 | 03-31-2007 11:05 PM |
