Rod end mod or other options? I'm looking to upgrade my suspension for the upcoming season. I'm cosidering two different options. Rod end mod on a set of big bores or one of these, the Jeepin Doug stand offs http://www.rccrawler.com/forum/chass...s-5mm-6mm.html or the Eric Delux big bore shock ends http://www.rccrawler.com/forum/chass...%2A%2A%2A.html . Just wanted to get some opinions. Thanks in advance. |
Re: Rod end mod or other options? I have Doug's stand offs and really like how they work with the Losi Crawlers on my Wraith. |
Re: Rod end mod or other options? I use both of them on a V4 Berg Beetlejuice. They both work great and Jeepin' Dougs allow you to get the shock spaced a little further from the frame with the included spacers. |
Re: Rod end mod or other options? Cool. Thanks for the replies. I'm not afraid of the rod end mod but I'd rather not do work I don't have to. |
Re: Rod end mod or other options? It depends on how long you want them to end up...With the 4" models you wouldnt want to do the rod end mod because they would be too long, with the 3.5" you could go either way depending on chassis, axles, etc. |
Re: Rod end mod or other options? By the way, you'll need the 5mm ones for Big Bores 4" or shorter. |
Re: Rod end mod or other options? Quote:
Thanks again for all the info guys. |
