RC Truck Snow Plowing Hey i was wondering if anyone. Attaches snowplows to the front of there Rc Trucks If you have ics let please post......! Cuz I am gonna ut a plow on my stampede. |
Re: RC Truck Snow Plowing |
Re: RC Truck Snow Plowing Where did you get that Ace? Or.. More likely knowing you, Can you make me one? :lol: |
Re: RC Truck Snow Plowing Made it, just knocked it up from some sheet metal. Works okay, moves up and down with the servo and angle change is manual... |
Re: RC Truck Snow Plowing Quote:
Re: RC Truck Snow Plowing On that one I just took the front most bolt out of the clod axle (the one where the stock bumper bolts on) and drilled it thru. Then I put a pin thru and that mounts the plow, it is also where it pivots up and down. Pretty crude but it worked. |
Re: RC Truck Snow Plowing Ya i have to see if i can find a plow or maybe make one then ya i'll jsut attach it solid. |
Re: RC Truck Snow Plowing I don;t know but same here we jsut got like 2 incehs of snow and that would be perfect |
Re: RC Truck Snow Plowing I was just thinking of getting like an 8" diameter pvc pipe an cutting it in half length-wise. Dunno about mounting yet but that'd be plenty strong enough. |
Re: RC Truck Snow Plowing I plowed my back porch and my front sidewalk with it last year. Only had about 2" of snow but it did it. |
Re: RC Truck Snow Plowing srry if this question is dumb it doesnt snow here so heres my Q why do u need to plow a sidewalk? unless u do it for fun :? |
True though... I was doing stupid childish stuff when you were in diapers! |
Re: RC Truck Snow Plowing my father and i were just debating this the other day. i actually sat down and built a whole plow assembly and everything using some white pvc pipe cut in half (i think it was a 7 or 8 inch pipe) and a metal frame w/ 2 servos. its 2 flaws are A) its so heavy that a good bump face plants the truck, and B) i never came up with a good way to mount it. i did try it out, but i was short of vehicles at the time, so i wound up hooking it up to a radio shack monster patrol :D yeah.... it didnt do very well lol im biting the bullet and getting either a modclod chassis or a TXT 1 before spring, so ill head on back to the drawing board :) |
Re: RC Truck Snow Plowing Ya Ace could u make me one please. :D :wink: |
Re: RC Truck Snow Plowing So you didn't use a full truck? If not maybe a full ~10lb truck could hold it up. How long was the pipe and how much did it weigh? Quote:
Re: RC Truck Snow Plowing How do u make a stampede Dual motor, and 4 wheel Drive. :?: |
You can order a kit from Swami here. It's for the Rustler but they're the same truck I believe. /Edit/ There's several threads/links about 4x4 Pede's on the Traxxas forums. |
Re: RC Truck Snow Plowing Thanks. |
