04-06-2012, 05:57 PM | #1 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
| BWD "Project X" Direct Drive Trans...so many applications!
This is a project that I've sat on for long enough. Meet the BWD "Project X" Direct Drive Trans. This was developed for a host of applications ranging from 1/10-1/8 scale go fast/FOFF rigs to LCC Axled Sporty rigs. While it appears very stout (intended to be near bomb proof), this proto only weighs as much as a bone stock plastic housing/geared AX-10 transmission with stock alum outdrives. That said, it comes in at under 2" wide in the vertical config, 3.2" L, and 2.25" tall in the vertical config (plus spur height). The motor is stationary, mounted at the very bottom, and the top shaft pivots for gear mesh/change adjustments. The top shaft is supported by 2x 6mm x 12mm bearings (there is an 8mm output version coming for big FOFF'ers and go fast rigs that will use even bigger bearings). The bearing nearest the spur is placed between the spur and that drive shaft yolk, to keep lateral load on the top shaft to a minimum. The mounting points for the trans are symmetrical front to rear so it can be mounted with the spur facing forward or rearward. The rigidity of the housing allows the chassis skid to be pocketed down placing the motor as far down as possible, without getting the drive shafts into the skid/lower links. Also note the drive shaft in this config is centered (and in the lay down config is only about 1/2" off center) which will keep your drive shafts out of your upper links. The lay down config will be posted in the near future. Anyway, keep in mind that this is a proto, but it's coming. BWD |
04-06-2012, 06:03 PM | #2 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: BWD "Project X" Direct Drive Trans...so many applications! WOW I need that.......... Regards Rick |
04-06-2012, 06:10 PM | #3 |
And here I've been messing with getting a ten-scte trans to work... I can get the drive shafts centered, but on a 12.5" WB, seems like driveshaft angle is a bit too extreme. Bad ass. What's the projected prove point on this? Last edited by TSK; 04-06-2012 at 06:13 PM. |
04-06-2012, 06:18 PM | #4 | |
| Re: BWD "Project X" Direct Drive Trans...so many applications! Quote:
Well it's pretty simply and extremely tough, not much can go wrong...but it'll be pushed anyway. The only part I have to outsource is the top shaft, so cost will stay down where I can make it worth doing. | |
04-06-2012, 06:24 PM | #5 |
Let me know when these are ready |
04-06-2012, 07:07 PM | #6 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Wow Good Balance, good COG, better ground clearence It's like a 3 in 1 package! I like it. Now were is the the "Project MX" (Mini) Hint Hint |
04-06-2012, 07:10 PM | #7 |
The mini x should be unveiled before and at ecc.
04-06-2012, 07:14 PM | #8 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
That is brilliant!
04-06-2012, 07:31 PM | #9 |
| Re: BWD "Project X" Direct Drive Trans...so many applications! |
04-07-2012, 05:14 AM | #10 |
I wanna be Dave Join Date: Nov 2005 Location: Here
Very cool Don. I can see some applications for that in my future. |
04-07-2012, 07:42 AM | #11 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Waaaaaay cool! If this can be mounted on a SCX-10 skid, I will definitely need one for my scaler, and I'm SUPER stoked about the mini version! Last edited by papabash; 04-07-2012 at 03:09 PM. |
04-07-2012, 11:28 AM | #12 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
Awesome...totally badass I'm in for one when they go into production. |
04-07-2012, 08:12 PM | #13 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Very sick Don, and is that a super wheel or what???? Also is there room to run 32 pitch? Later, Farmer |
04-07-2012, 08:18 PM | #14 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Awesome
04-07-2012, 08:26 PM | #15 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
I see a few of these in my near future |
04-07-2012, 09:03 PM | #16 | ||||
| Re: BWD "Project X" Direct Drive Trans...so many applications! Oh I will, and it will be very soon! Thanks bud! Quote:
Surprised it took so long for someone to say something. I just wanted something other than white under it and had that wheel sitting on my shelf. It made it easy to spin and shoot pics as well. I guess super wheel would be an understatement. It's and 8" diameter beadlock for one of the robots I've been developing. Thanks my friend! I have a feelin these are gonna be used on a lot of widely diverse projects. If I'm right, the price for this bomb proof complete package is gonna be very nice as well. The spur gets a custom cnc machined 6 bolt adapter that utilizes a 3/32" x 1/2" drive pin...beef I'm planning to have a handful of these with me at ecc, and some in rigs to demo there! BWD | ||||
04-07-2012, 09:19 PM | #17 |
You coming to ECC??? Hope to meet up with ya again The robot stuff sounds super cool!!! Later, Farmer |
04-07-2012, 10:54 PM | #18 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Must have, Great job Don
04-08-2012, 05:40 PM | #19 |
| Re: BWD "Project X" Direct Drive Trans...so many applications! Sick! email sent!! |
04-08-2012, 06:32 PM | #20 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
Man I want one bad hurry up and get these in production bro!
BWD "Project X" Direct Drive Trans...so many applications! - Similar Threads | ||||
project "Punisher" BWD Low Pro | MudboyNJ | Losi Mini-Rock Crawler | 58 | 08-27-2013 12:44 PM |
BWD "Vertex" Micro-Locks on the production BWD "Micro Wedge" | billet works | Losi Micro-Rock Crawler | 162 | 07-18-2010 09:36 PM |
MRC "motor noise" and L-trail chassis "drive shaft" | joeel | Losi Mini-Rock Crawler | 6 | 03-04-2010 04:38 PM |
BWD new "Mini-Locks" - 1.9 "Vertex" | billet works | Tires and Wheels | 21 | 10-26-2009 08:56 AM |
