08-07-2013, 02:58 PM | #21 | |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 | |
08-07-2013, 03:20 PM | #22 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
It's that non lipo. When you bind up and start cranking on your throttle, it over draws your batteries to where they can't provide the amprage.
08-07-2013, 04:34 PM | #23 | |
| Re: Wreckluse RC rock crawler info! Quote:
Voltage applied, motor turns, gearing (spur & pinion) & rig weight all have an effect. A low turn motor and/or high gearing (more than ~5:1 pinion to spur) can make for "road speed" but kill torque. Using NiCD or NiMH packs is not bad, but they are big & heavy compared to LiPO. Crappy pack connectors (Tamiya is among the WORST) can also kill power. | |
08-31-2013, 05:47 PM | #24 |
Newbie Join Date: Apr 2013 Location: Mt. Washington
| Re: Wreckluse rc rock crawler info!
Heres an update what I have done. I switched to a 11.1 lipo batt and now its faster than a wrath and still I have no torque. Do I size down the mane gear or the diff's? The motor came with a box of parts, I have know idea what it is but it was in a standard scx10 frame. It seems to be a bit longer that the factory Axial "can". As for binding I have a little from the rear I cant seem to get the pinion angle right.
08-31-2013, 06:49 PM | #25 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
Yeah dude, sumthins outta wack. Even with your gearing all wrong, you'd be able to climb. You might have to goose the throttle, to get your rpm's up, and your motor would get hot quickly, but climb you would. This is electronics, i think.
09-04-2013, 12:26 PM | #26 |
well i picked up a rooster crawler esc and im having the same problem so I guess I'll replace the motor and see if that helps.
09-04-2013, 06:46 PM | #27 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
What gearing are you running on the spur and pinnion? What motor Specifically? I suggest a 35t to start with. |
09-08-2013, 09:34 AM | #28 |
there stock 28/30. I'm starting to think it is the motor I going to switch to a 55t motor and see what happens. Like I said I have no Idea what kind of motor I have is so thats where I going to start.
Wreckluse rc rock crawler info! - Similar Threads | ||||
just got my new used wreckluse love it but need some info | mtgrizzlymn | General Scale Talk | 8 | 03-21-2012 01:43 AM |
Rock crusher x/t info | team423 | Tires and Wheels | 3 | 03-05-2012 06:51 PM |
Wreckluse built for speed and bashing info? | PowerCrazy | 2.2 Scale Rigs | 0 | 04-21-2011 04:43 PM |
new bright jeep rock crawler info please | william g | Chit Chat | 14 | 02-28-2006 07:52 PM |
