07-07-2012, 05:33 PM | #21 | |
RCC Addict Join Date: Apr 2011 Location: San Diego
| Re: Carter Fab & Machine Custom Scaler Axle Housings Quote:
Basically want the wraith center and scx10 width. Hate the 2 piece scx10 housings....makes diff maintenance annoying! | |
07-07-2012, 05:36 PM | #22 | |
Edit: doh, just saw the post thanks | |
07-07-2012, 05:37 PM | #23 | |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Clear Eyes, Full Hearts, Can't Lose | |
07-07-2012, 05:40 PM | #24 |
Unless you want plastic housings to save money, then I can just narrow them. It's the same $50 as a normal plastic Wraith width centered diff. Parts not included. Clear Eyes, Full Hearts, Can't Lose |
07-08-2012, 02:17 PM | #25 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
Wow man those are sweet.
07-09-2012, 04:28 PM | #26 |
Updated almost finished pic of front "Ultimate 9" housing in first post.
07-09-2012, 10:56 PM | #27 |
I'm HUGE in Japan! Join Date: Dec 2011 Location: Clearwater - home of the endless summer
Could you possibly shave the gear housing on the aluminum VP ax10 axles? or maybe do a hybrid plastic pumpkin / steel tube ax10 axle with some higher than stock clearance? Last edited by ScaleDustin; 07-09-2012 at 11:00 PM. |
07-10-2012, 06:44 AM | #28 |
07-17-2012, 05:30 PM | #29 |
Well you officially don't have a southern build without these. Just sayin!! Just need to weld link mounts on the rear and build the front. Replaced as much hardware as I could with the new scale hardware. BlackRock 60 rear housing Carter Fab & Machine: Hand Made Customs |
08-02-2012, 09:55 PM | #30 |
| Here's what's next folks. These next 3 custom housings will be up for sale as soon as they are completed. I ordered a bunch of stuff, combined with left over mock up parts(new), to make some stuff that hasn't been made, but there is definitely a home for these. First one will be a centered diff, Wraith width, steering axle. Can be used front or rear, but designed for rear application to help you reach that extra bit of scale. All plastic housing. Can also run lockouts and make it non steering in the future. Comes with Axial Universals custom fit for this housing, stock plastic c hubs and knuckles. You will need everything else to make it complete. Designed to use the VP AX-10 axle truss(vps0441) and VP AX-10 servo mount(vps04451). The next 2 housings will be SCX-10 width, centered diffs. Will come with Axial Wraith Universals for the steering axle and designed to use the Wraith c hubs and knuckles or XR-10. The rear axle will be locked out and use Wraith lockouts. Included with the housings are axle shafts and rear lockouts. You will need everything else to complete. Designed to use the VP AX-10 axle truss(vps0441) and VP AX-10 servo mount(vps04451). Updates to come next week with pics and finished housings. Pm me for pricing and dibs. I will post up if one gets spoken for. There are only the above 3 available at this time. Thanks Clay Carter Fab & Machine: Hand Made Customs |
08-02-2012, 09:58 PM | #31 |
The rear Ultimate9s is done. Also has titanium shafts. Carter Fab & Machine: Hand Made Customs |
08-02-2012, 10:15 PM | #32 | |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
08-03-2012, 06:55 PM | #33 |
The centered diff, Wraith width steering axle is done. I'm going to sale this as a complete ready to drop in unit. Will be going in for sale section soon. Carter Fab & Machine: Hand Made Customs |
08-03-2012, 08:02 PM | #34 |
| Re: Carter Fab & Machine Custom Scaler Axle Housings |
08-03-2012, 10:43 PM | #35 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
I may have missed it, but which axles can be used for the Axial Honcho? Great work |
08-07-2012, 06:04 PM | #36 |
Quarry Creeper Join Date: Sep 2008 Location: NW San Antonio
Great job on the centered diff. Very sweet.
08-16-2012, 09:16 AM | #37 | |
Will sale it complete or bare housing with shafts. Pm me if interested. Carter Fab & Machine: Hand Made Customs | |
08-16-2012, 09:17 AM | #38 | |
08-16-2012, 04:13 PM | #39 |
08-20-2012, 05:21 PM | #40 |
Been doing some measuring. To get them SCX/AX-10 width it will require more machining than I'm willing to put in them for the price. The problem are the link mounts. There you can see that the link mount on the new housing needs to be brought over a bit and that requires drilling new holes and milling flats for the link mounts. What I can do is make the housing .625(5/8") wider than the stock SCX/AX-10 housing and not have to do more work. So that would add .3125(5/16) to each side. It will take 2 housings just like the centered diff for the wraith but a lot less work. But then you will also have to modify 2 long side shafts again, which is getting away from what I was hoping to just use the short side shafts from the wraith. So I guess its once again up in the air for the end user. Anything is possible but nothing is gonna just fall in place like I had hoped. I will build whatever you want, just take into consideration the above mentioned Carter Fab & Machine: Hand Made Customs |
Carter Fab & Machine Custom Scaler Axle Housings - Similar Threads | ||||
Carter Fab & Machine T-Shirts | CarterFab | Vendors Miscellaneous | 4 | 01-19-2013 10:07 AM |
