Thread: Loud R2 tranny w/ disconnect.
Old 09-01-2012, 01:49 PM   #1
Default Loud R2 tranny w/ disconnect.
I have a R2 tranny with a Novak brushless motor. The tranny sure makes a lot of noise. Wondering if anyone has this same problem or if it's just the way it is.
audiguy209 is offline   Reply With Quote
Old 09-01-2012, 02:22 PM   #2
All the r2s I ever had or ever seen have always been a load transmission because of the course gear pitch the internal gears have, but when the motor pinion mesh is even I little off it will be even louder
benoj is offline   Reply With Quote
Old 09-01-2012, 03:48 PM   #3
Yeah I pulled it apart to see how everything was seated and everything is fine. Guess I just have to live with it.
Old 09-01-2012, 06:36 PM   #4
Default Re: Loud R2 tranny w/ disconnect.
What type of grease are you putting in it?
ScaleReady is offline   Reply With Quote
Old 09-03-2012, 04:29 PM   #5
I used to have a couple R2 transmissions, and they're a ton louder than an Axial unit... but I do like their metal housing!
grob23 is offline   Reply With Quote
Loud R2 tranny w/ disconnect. - Similar Threads
loud R2 tranny scale4x4 Newbie General 9 09-07-2009 08:08 PM
How loud is your RC4WD R2 tranny? Barnaby General Crawlers 22 02-01-2007 04:52 AM
How loud is your pede tranny? CronusTRD Tamiya TLT Crawlers 12 12-18-2006 10:04 PM
