05-01-2004, 12:45 PM | #1 |
Moderator Join Date: Apr 2004 Location: In my head
| Clod, TXT-1, Juggernaut Wheels???
Does the TXT-1 and the Juggernaut use the same axles (are they exactly the same)? Does the wheels for a Clod, TXT-1, and Juggernaut interchange? I thought I read somewhere to run Clod wheels on a TXT-1 or Juggernaut that you had to use the outer axle from a clod, is htis correct? |
05-01-2004, 01:32 PM | #2 |
| Re: Clod, TXT-1, Juggernaut Wheels???
Axles in the TXT/Jugg2 are the same, possible different top case piece for top link mounts or not. Jugg1 is weaker and slightly different, avoid. Wheel issues: I stole this from another site(RCMT).... TXT on left.. Clod/Jugg on right TXT-1 --------------- Tread: Front & Rear-11.02" (280mm) (wheel centers) Track: Front & Rear 15.15" (385mm) (total) Juggernaut & Clodbuster ---------------- Tread: 272mm (wheel centers) Track: 14.75 in. (375mm) (total) |
