01-29-2007, 09:54 PM | #41 | |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I also did dezfans stealth mod of 100 grit sand paper! | |
01-30-2007, 03:59 PM | #42 | |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
I didn't want the revo yokes on it as I wanted to keep it scale looking as it was going on my Trail beater. While testing it broke so I needed something stronger. | |
01-30-2007, 04:15 PM | #43 |
Rock Stacker Join Date: Jan 2006 Location: Clackamas
Well here is my version of the spool for the t3 what do ya guys think? any suggestions |
01-30-2007, 04:19 PM | #44 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
What do we think? pshh, that'll never work! Actually, pretty sweet. Wish I had a lathe. |
01-30-2007, 04:22 PM | #45 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Nice job on the spool...I see a trip to Uncle Bob's garage coming soon |
01-30-2007, 04:53 PM | #46 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I just remove the material on opposite side of the inside of a maxx female shaft. Then it slides right over the outdrive and is a snug enough fit that it doesn't need a pin. If you need a pic I can show you.
01-30-2007, 04:57 PM | #47 | |
Double J, how did you get it to slip? W/ BL and 8 cells my slipper would give first? | |
01-30-2007, 04:57 PM | #48 | |
01-30-2007, 07:19 PM | #49 | |
Rock Stacker Join Date: Nov 2006 Location: Tulsa
01-31-2007, 05:07 AM | #50 |
Rock Crawler Join Date: Jan 2006 Location: commerce twp.
frankyrizzo, i would also like to see a pic of your mod, i'm having a bit of trouble trying to drill out the yokes without a drill press, they keep breaking thanks. |
01-31-2007, 06:40 AM | #51 | |
Rock Crawler Join Date: Feb 2004 Location: Michigan
01-31-2007, 07:50 AM | #52 |
I just remove the material shown in the pic on the female maxx shaft all the way down. Leave the other opposite ones because they slide into the slots on the output cups.I used to use a razor of sort but I recently used a soldering iron. ***DO NOT try this if you do not have very good command of a soldering iron!!!*** You will riun the shaft if you are not careful. Obviously cut it to the size of the output shaft before removing the material and watch for gear clearance issues. You may have to grind the Aluminum away a bit for clearance as well on the spur side. It is a snug fit and you can add a drop of CA if you want. I have never had any issues with this mod. I also use a PVC pipe cutter for cutting shafts. Cuts fast and clean and no more burrs. Last edited by FrankyRizzo; 01-31-2007 at 07:54 AM. |
01-31-2007, 09:16 AM | #53 |
thanks for the pics. i might have to try that. rcrcacer thanks for the offer just trying to keep my body busy during the day it gets quite boring during the day all by myself. |
01-31-2007, 09:19 AM | #54 |
That's slick Rizzo! I'm going to have to try that! |
01-31-2007, 09:31 AM | #55 | |
I was running a 90t spur and a 13t pinion with a 45 lathe? roydelburg - I could use one or two of those. Rizzo I like the mod as well. | |
03-11-2007, 02:14 PM | #56 |
Quarry Creeper Join Date: Feb 2007 Location: Fresno
Roydelburg, do you have any plans to sell any of those spools? It looks like the perfect solution to my tranny problem. With all the people using this tranny in crawlers, why doesn't one of the crawler shops offer something like this for sale? |
03-11-2007, 07:39 PM | #57 |
Built, not bought Join Date: Oct 2004 Location: Gresham
He doesn't but,I do.Watch the vendors section.They should be ready this week if everything goes as planned. Pat |
03-12-2007, 04:43 PM | #58 | |
I've been waiting.. I'll be needing some. it will make this thread obsolete | |
