11-13-2012, 06:38 PM | #1 |
Newbie Join Date: Oct 2012 Location: Ontario, Canada
| Home Made links
I am trying to make links for my SCX10. I know that everybody says traxxas ball ends, but what size brake line do you use, or do you use something other then brake line. Also what size threaded rod do you use? Thanks.
11-13-2012, 06:52 PM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
| Re: Home Made links
8/32 threaded rod with 1/4" brake line. Try home depot for the threaded rod,they were the only ones that had it when i made mine. I used revo rod ends. |
11-13-2012, 07:47 PM | #3 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
| Re: Home Made links
Ace hardware. Grab some 8-32 all-thread and then go to the section where they have the small brass, aluminum and stainless tubes. There's an aluminum tube that sleeves the 8-32 perfectly. Or, there's a combination of brass tube and stainless tube that makes a nice, strong link that slides over rock like butter. (Brass tube slides inside the stainless.)
Home Made links - Similar Threads | ||||
My Home made links. | ouchman | Axial SCX-10 | 5 | 11-06-2012 05:54 PM |
Home made lower links ? | heavy chevy | Team Losi Comp Crawler | 11 | 06-16-2012 07:28 PM |
home made bent links | mdchris | Team Losi Comp Crawler | 16 | 10-24-2011 03:50 PM |
home made links | Losi man | Losi Mini-Rock Crawler | 5 | 08-21-2009 12:20 AM |
