12-08-2012, 08:40 PM | #21 |
Pebble Pounder Join Date: Aug 2012 Location: Canada
| Re: Spektrum DX4S Thread
well i have to say I had some bad luck thus far with the new sr410 receiver that comes with the dx4s ..hooked everything up tonight in my crawler with an m2 dig , installed the receiver and turned it on ...everything was fine bound to the radio , and i did my programing which in total probably took 30 minutes ..once i was done setting the esc i turned it off to tidy up my wires and finish up..was off probably about the same length of time 30-40 minutes ...when i went to go turn it back on and plugged the battery in it esc and servo were unresponsive ..esc would light up but would not calibrate or anything , also steering servo would not work either ..figured maybe a bad connection somewhere but checked all my joints and found nothing ,tryed a different servo too to see if it was a faulty servo but did not work either ..at last i decided to try the sr300 receiver i had in my crawler before hand and see if it would work or anything ..sure enough everything was working perfect .i never abused the receiver at all so what i,m curious about is how good is customer service through Horizon going to call LHS on monday see what they say too ...what you guys think..
12-08-2012, 08:52 PM | #22 |
Quarry Creeper Join Date: Jul 2011 Location: charlotte
eh its like all electronics shit happens..im sure they will help you out!!
12-09-2012, 06:23 AM | #23 |
| Re: Spektrum DX4S Thread Yeah i,m hoping so ..kind of a bummer only was turned on and used once haha ...i,m not dumb either so things were plugged in correctly ..going to call mighty small cars tomorrow see what they tell me ..
12-09-2012, 07:13 AM | #24 |
Pebble Pounder Join Date: Nov 2012 Location: Australia
Have you tried re binding it?
12-09-2012, 07:16 AM | #25 |
| Re: Spektrum DX4S Thread |
12-09-2012, 11:11 AM | #26 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
I have had spektrum receivers in the past that would loose bind. Sounds typical of nee products being pushed out fast
12-09-2012, 11:57 AM | #27 |
yeah i don,t think it is just the case of losing the bind i tryed everything last night ..gong to mess with it some more today when i get home ..and call horizon in the morning if i have no luck ..
12-09-2012, 01:53 PM | #28 |
Have you left it plugged in for longer then just long enough to know it doesn't work? Um having a similar issue with a marine Spektrum rx.. tho if its unplugged an plugged back in, then my servo will get juice first, then 10 seconds later the fxr fires up, then all is well... Never had these issues before, just with this 2ch marine rx.. my dx-3c is compatible with it.. Im not sure the problem, but it works after letting it calibrated or whatever it does.. As for the new tx.. too little too late.. love me Spektrum tx's,, till I needed a 4ch.. so I went with a airtronics mt-4.. haven't looked back nor will I! It's an awesome tx an works amazing! Now to just get some rx's to replace the hale dozen Spektrum I have.. Last edited by winnerone23; 12-09-2012 at 01:56 PM. |
12-09-2012, 04:09 PM | #29 | |
| Re: Spektrum DX4S Thread Quote:
12-09-2012, 07:15 PM | #30 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Try a new model memory and start fresh. I had to do that once with my DX3R and afterward never had any more issues.
12-10-2012, 07:09 AM | #31 | |
Really strange but did just this last night and it worked ..i don,t understand i tryed the same thing the night before and no results but again last night and it did ..strange .. | |
12-11-2012, 04:37 AM | #32 |
Newbie Join Date: Sep 2009 Location: birmingham
i am eagerly awaiting some feedback on this handset, i love my 3s though i have now run out of model memory on it, could be tempted by a 4s if it does dual esc and proportional dig. |
12-11-2012, 05:53 AM | #33 |
12-11-2012, 06:50 AM | #34 |
I better start warming up my credit card then if im going to buy one of these and a HPI WR8 flux. Any chance of a brief review when you have a chance, a direct comparison with the 3s would be awesome. |
12-11-2012, 11:24 AM | #35 | |
Moderator Join Date: Jan 2004 Location: chicago
does the dx4 have this? | |
12-11-2012, 01:56 PM | #36 |
| Re: Spektrum DX4S Thread Yeah i,m quite certain you could set up the switch in the grip normally used for steering rate on other dx radios ..i will look into it for you though
12-11-2012, 01:57 PM | #37 |
12-11-2012, 06:37 PM | #38 |
Im thinking about getting this radio and seeing if I can put all the guts in a DX3R case.
12-23-2012, 05:55 PM | #39 |
Newbie Join Date: Nov 2011 Location: tinley
It does have dual esc mixing and momentary aux switches.
12-23-2012, 05:57 PM | #40 |
Now if they would just make it a 4r pro, would be great.
Spektrum DX4S Thread - Similar Threads | ||||
Spektrum dx4s 4-ch dsmr radio system | mp3ranger | Electronics | 14 | 06-01-2014 05:35 PM |
