12-04-2012, 03:46 PM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| The definition of a "Sportsman" rig Please
As it states. I'm building what I would consider a Sportsman rig from what i have seen vids of but I may not actually qualify for a sportsman class. Could someone supply the specs for a sportsman rig please? |
12-04-2012, 04:13 PM | #2 |
| Re: The definition of a "Sportsman" rig Please
You'll find what you're looking for in the rules thread |
12-04-2012, 04:19 PM | #3 |
Shafty, no dig. Just look at the rules. |
12-04-2012, 07:58 PM | #4 |
Took a bit to locate (Last 2 pages of the rules of coarse!!) 12" wide X 12.5" long with the AR60's. Just have to remove the Dig and shes GTG. Thanx fellas!!
12-05-2012, 08:34 AM | #5 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Any axle configuration that is shaft driven and meets the dimensions you mentioned above. Ax10, LCC, AR60 etc.
12-05-2012, 04:15 PM | #6 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Sportsman (MOA is optional) is different than 2.2s, here are the "rules" for sportsman... Sportsman Class Rules Guidelines Sportsman Class is a fun class intended for local drivers enjoyment. ▪ 1- Drivers are require to have fun! ▪ 2 - Vehicle wheelbase is limited to a maximum of 12.5 inches. ▪ 3- Vehicle track width is limited to a maximum of 12.5 inches. This is determined by measuring the bottom of the outer most edge of the front and rear tires while the vehicle is sitting on level ground. ▪ 4- Vehicle is limited to 2.2 inch wheels/rims or smaller at the bead surface. Wheels may be modified, provided that the tire bead surface does not exceed 2.2 inches in diameter. With a tire mounted, no exterior component of the wheel, including but not limited to, the bead lock ring shall exceed 2.55". Tires may be modified from other sized tires using only a pliable rubber, but must not exceed a total uncompressed outer diameter of 6 inches. ▪ 5- Vehicles are limited to 2-wheel steering only. ▪ 6 – The body and Bodiless vehicles same as Class 2 vehicle –2.2 (See Sec. 2.3.5 & 2.3.6) ▪ 7 - Vehicles are limited to the use of 2 radio channels (one for steering & one for throttle) only. Neither channel can be used to perform more than one function. Radio systems with more than 2 channels are allowed, but only 2 channels may be used to control the vehicle. ▪ 8- Vehicles are limited to 1 ESC & 1 servo only. ▪ 9 - (OPTIONAL) Vehicles are limited to 1 motor powering both of the axles. |
12-06-2012, 12:16 AM | #7 | |
| Re: The definition of a "Sportsman" rig Please Quote:
A simple one motor limit is sufficient. Then it's fine to have that motor mounted anywhere on the rig, propelling any combination of the four wheels. | |
The definition of a "Sportsman" rig Please - Similar Threads | ||||
WINNER**Krawler Konceptz "Happy Sportsman Skins" Give Away | Krawler Konceptz | General Crawlers | 30 | 05-17-2011 07:21 AM |
SCX-10 and the definition of "scale" | JasonInAugusta | General Scale Talk | 99 | 07-14-2010 12:06 PM |
UNIMOG CR-01 "Up and Down at Dirt and Rock Hill" - Portugal. High Definition. | PMateus | Scale Videos! | 0 | 09-20-2009 06:26 AM |
