Thread: How do I make my SCX less "jumpy"
Old 12-03-2012, 11:55 PM   #1
Default How do I make my SCX less "jumpy"
The title says it all, i've pondered at the idea of lead weights added to the frame, in a similar distribution as a regular truck.
Has anyone got any input or should this be good to go?
(I'm talking about adding 4-5 lbs to the truck.)
Climber is offline   Reply With Quote
Old 12-04-2012, 02:23 AM   #2
Default Re: How do I make my SCX less "jumpy"
Beef tubes and knuckle weights. Felsenfest spools. This all gets the weight really down low. Then start playing with chassis weight to mimic 1:1 movement if desired.
808DA6 is offline   Reply With Quote
Old 12-04-2012, 02:26 AM   #3
heinie_21's Avatar
Some heavy wheels will probably help. Aluminum with fat Beadlock rings.
Knuckle weights.
OR (not and) maybe soften your foams?
Sent from my SCH-I535 using Tapatalk 2
heinie_21 is offline   Reply With Quote
Old 12-04-2012, 05:30 AM   #4
How do you mean less jumpy? Bouncy? Throttle jumpy? Springs too soft an the body bounces all over an throws you off?
Easier ways to get weight, like said above, then just dropping it on ur truck rails an on ur drive train..
For most it would be, steel bumpers, sliders,(from Bent Metal Works, is my stuff) a hard body, scale points, etc.. not just flopin it on ur chassis rails.. just my thoughts on it.. depends on what you do with it
winnerone23 is offline   Reply With Quote
Old 12-04-2012, 05:37 AM   #5
If you are talking bouncy like when you hit the throttle, you can also try mirroring the xmsn. I did that and it made a huge difference. But like winnerone23 said, we kinda need a little more info on what you mean by jumpy.
massRCdude is offline   Reply With Quote
Old 12-04-2012, 08:00 AM   #6
Like others have asked, please clarify "jumpy". Does "jumpy" mean twitching as you apply throttle or steering? Or does "jumpy" mean bouncing while simply driving, or trying to conquer an obstacle?
Twitching is, more than likely, electronics. Bouncing while trying to conquer an obstacle is better remedied with foam tuning and shock tuning. Bouncing while simply driving can be tricky to deal with. In my opinion, weight in the wheels would help, as well as shock tuning and maybe foam tuning. Keep in mind that adding weight (and potentially too much) to solve the bouncing while driving can adversely affect the crawling performance.
Either way, share the situation in which you are experiencing the "jumpy". Also, share your rig's set-up.
My advice would be to NOT add the 4-5 pounds like you are proposing.
btoungette is offline   Reply With Quote
Old 12-05-2012, 08:29 PM   #7
By jumpy, I'm talking about when the truck is stuck, and you go open throttle and it just jumps around, I mean, I want it to have the weight to bite down into the rock. Just like a 1:1 Really.
Sorry for the long response.
And the rig is completely stock.
I suppose the best way to explain what I am trying to achieve is a 1:10 weight of a 1:1
Old 12-05-2012, 08:35 PM   #8
Are ur wheels or tires vented? What tires? What foams? What shocks? What springs? A pic of ur rig would help..
Wheel weights help bite but hurt drive train.. knuckle weights, beef tubes, softer foams maybe, vent ur wheels if there not.. how much weight is up top?
Some hop when you throttle out, just happens.. some times its the only reason you make it out.. some tiMEa ya just have to slow down an let ur tires do the work.. still need more info on rig setup..
Old 12-05-2012, 09:19 PM   #9
Everything is stock, I've vented the wheels and am running 2.2 Flat Irons, I go slow enough, but it still hops around, I'm looking for scale handling. For Foams I am running the stock memory foams that come with the Flat Irons.
But yeah, everything is stock, and the rig weighs 7.1 lbs.
Old 12-05-2012, 09:24 PM   #10
Scale Detail Engineering
have you moved your battery lower?
If no, do that and add weight to your wheels... start with a 1-3 oz.
and then read this: Tips and Tricks Thread
johnnyh66 is offline   Reply With Quote
Old 12-05-2012, 09:47 PM   #11
Like said b4 move weight lower I wouldn't add weight to the wheels but to the axles themselves sounds like u need more unsprung weight to me
fordsuperduty is offline   Reply With Quote
Old 12-05-2012, 09:52 PM   #12
adding weight to the wheels works.
Old 12-06-2012, 12:29 AM   #13
Other than the obvious (Beadlocks, heavier rims, etc.) How could I add weight to the wheels?
Old 12-06-2012, 12:38 AM   #14
lead stick on weights: Buxom Melons: Class 2 VW Beetle
Old 12-06-2012, 02:15 AM   #15
That looks really ingenious, where can I get these weights?
Old 12-06-2012, 03:36 AM   #16
I'd be looking at suspension. Swap out to a semi droop set up with external springs for compression and small inner springs inside the shock for extension.
With no down travel you'll just pick wheels up and bounce, with no calving or springs to control down travel you'll just tip and flop.
On my cell so don't have a reference pic of the shock. I'm sure someone will be able to post one though
sierrajim is offline   Reply With Quote
Old 12-06-2012, 03:36 AM   #17
or window lead strip, though not sure if its available over there.
Its a much neater solution than the stick on lead weights.
darkangelv24 is offline   Reply With Quote
Old 12-06-2012, 07:11 AM   #18
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Stop giving it coffee?
Sorry, on a roll with these.
I have some presegmented lead that is pretty easy to apply around a wheel:
Keep in mind that as you add more weight your drivetrain starts to suffer. if you add 4-5 lbs it will be brutal on your drivetrain and you can plan on sucking a lot of battery.
If you are going to bulk up I would look at some some Vanquish axle shafts and metal driveshafts. Let me know what length you neeed is those are too short because have a few that I still need to add to the store.
Are your rims vented? Just curious.
And as it has been said, suspension plays a huge role in how your truck reacts.
Is it 100% spring? 50/50 sprung droop? Playing around with those things will give you some options and it can be pretty fun (and educational) to tune.
For what it is worth, my truck is 9lbs 6oz when dry.
Locked Up is offline   Reply With Quote
Old 12-06-2012, 07:26 AM   #19
@LockedUp
+1 Respect for your coffee comment.
Anyways, Can you explain what presegmented lead is?
My rims are vented, and I have a 60/40 droop setup. But it just seems like it wants to hop up the rocks.
What I mean is, it gets stuck too damn much on the simplest of rocks.
as for driveshafts, here is what I am running http://store.rc4wd.com/Scale-Steel-P...5mm_p_819.html
Old 12-06-2012, 04:30 PM   #20
Perhaps the full spec list on your truck might help you get it tuned via PC.
So what shocks, shock oil and springs are you running?
Are your tyres vented? with what foams?
Weight "can" help, proper suspension set up will help more. If your truck is light, set the suspension up accordingly.
How do I make my SCX less "jumpy" - Similar Threads
Will the xr10 make a good "mini clod" monster truck? rocresq Axial XR10 3 11-25-2011 12:35 PM
HRCC's #3 comp "Da Make-Up", august 31st.....kahalu'u pond RydeFab Hawaii 25 09-16-2008 01:13 AM
HRCC's #3 comp "Da Make-Up", august 31st.....kahalu'u pond RydeFab Competitions 0 08-18-2008 03:27 AM
