01-02-2013, 08:43 PM | #1 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Big Bore Travel
Can you guys help me out with big bore travel length for the 3 different big bore shocks and with each different lengths what mini-t springs work better fronts or rears. 3.5" (part #2660) 3.75" (part #2661) 4" (part #2662) Thanks |
01-02-2013, 10:17 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Okanagan Falls B.C.
| Re: Big Bore Travel
I run BB 3.5's with Mini T fronts, and they fit perfect. Mini T Fronts measure, 1 3/8" long Rears measure, 1 3/4" long There's no rules, if you used the longer rears, on 3.5s it will increase the spring rate. But I would'nt. I'm not sure which would fit the 3.75's etc. I hope I helped. |
01-04-2013, 10:14 PM | #3 |
| Re: Big Bore Travel
The measurement I'm looking for is the amount that the shaft goes into the shock (without limiters of course).
01-07-2013, 08:44 PM | #4 |
Rock Crawler Join Date: May 2007 Location: Arnold
| Re: Big Bore Travel
4 inch big bores with pink springs and jeep'n dougs spring cups traval 1 inch from fully extended to fully compresd.Is this what you were looking for.
01-07-2013, 09:08 PM | #5 |
| Re: Big Bore Travel
Yes sir |
01-10-2013, 01:15 PM | #6 |
| Re: Big Bore Travel
Bump on the 3.75"
Big Bore Travel - Similar Threads | ||||
traxxas big bore??? | bigemike | Axial SCX-10 | 1 | 08-21-2012 09:11 PM |
Big Bore Shocks? | carp40 | Axial AX-10 Scorpion | 6 | 07-20-2010 11:15 PM |
Big Bore Shocks | 4X4XFAR | General Crawlers | 7 | 09-08-2005 08:45 PM |
