Thread: Foam cutting
Old 08-27-2006, 09:20 PM   #1
Default Foam cutting
Ok, i just got some brand new moabs and was wondering how to cut the foams 'cause they're too hard for a 3lb truck, but to soft without foams. Please help, Pics apreciated
'75 Bronco is offline   Reply With Quote
Old 08-28-2006, 08:10 AM   #2
hmm what i think would work good. is to cut the foam in half. so the diamater to start is 5" the new diamater would be 2.5" this will let the tires sag but give you support once it reaches the foam, should work good. or you could grind out the midle on the 'contact' part of the foam making a U of the top of the foam. or a severe star cut would work too. i don't have any pics, sorry, check the wheel forum and seach for moab foam cut theres pics there
Bknight is offline   Reply With Quote
Old 08-28-2006, 05:32 PM   #3
I'd like info on the star pattern thanks.
Old 08-30-2006, 05:07 PM   #4
bump...
Old 08-31-2006, 04:46 AM   #5
just like it sounds, take the foam out and cut out some triangles in it so it looks like a star
payableondeath6 is offline   Reply With Quote
