01-06-2013, 09:58 AM | #1 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| ax-10 axle
I just found that one of the screw holes that hold chub on is striped. Is there an easy fix for this with out buy a new axle housing? I looked for a fix but couldnt find one. please help thanks |
01-06-2013, 10:23 AM | #2 |
| Re: ax-10 axle
I build short steel beef tubes out of 1/8" pipe. Drilled & tapped for 3mm they keep everything locked down.
01-06-2013, 10:27 AM | #3 |
| Re: ax-10 axle |
01-06-2013, 11:50 AM | #4 |
| Re: ax-10 axle
Crap picture but you get the idea. I wrap them in 2 layers of electrical tape so they are a snug fit in the housing. I also tap a hole in them to pin them in place from the front. |
ax-10 axle - Similar Threads | ||||
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 41 | 06-24-2012 06:57 PM |
rear straight axle lock out's for tamiya tundra highlift axle | tundrafan01 | General Scale Talk | 9 | 05-19-2011 01:30 AM |
Lube TLT-1 stub axle to inner axle shaft or run it dry??? | Natedog | Tamiya TLT Crawlers | 5 | 01-17-2006 02:53 AM |
