01-17-2013, 04:04 PM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| brazing vs welding: are both enough for a chassis
i'm thinking about building a truggy and want to do the tubework myself. the question I have is whether or not brazing brake line going to be strong enough. I can do brazing and have the equipment but I was concerned about strength. the base of my project will be an scx10 frame.
01-17-2013, 04:09 PM | #2 | |
Quarry Creeper Join Date: Mar 2010 Location: murrieta
| Re: brazing vs welding: are both enough for a chassis Quote:
01-17-2013, 04:10 PM | #3 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
I don't see why it wouldn't hold up, it's not like your going 40mph then crash into a building. I'm going to braze up a roll bar for my Jk and if that goes well then I'll fab up at full tuber for my Foff. I say go for the brazing because you already know how to do it. |
01-17-2013, 04:22 PM | #4 | |
| Re: brazing vs welding: are both enough for a chassis nice work. is that made to fit to an scx10 frame? do you have a build thread with more pics? my plan was to make a modular frame. rear tubework like yours then an exo-cage / front bumper over the cab that swings up to give me access to the electronics. Quote:
01-17-2013, 04:40 PM | #5 | |
01-17-2013, 04:54 PM | #6 |
Newbie Join Date: Oct 2005 Location: Sadieville
Brazing is as strong as a weld when done correctly. Takes a little practice- but is easy. |
01-17-2013, 04:54 PM | #7 |
| Re: brazing vs welding: are both enough for a chassis Just a few of mine over the years, take your time and you'll get it in time. |
01-17-2013, 05:14 PM | #8 |
I appreciate all the input. and jckabob, I will be looking up some of the threads. the pics are in the ballpark of the type of things i'm looking to do.
01-17-2013, 05:52 PM | #9 |
I'm very unskilled at brazing, and never really considered brake line all that structural. That said, I've witnessed other peoples properly brazed, properly triangulated brake-line exo's survive ridiculous tumbles without harm. I'd say the strength is completely dependent on the builder. If done properly, it's plenty strong. That is a sick Toyota Truggy BTW! |
01-17-2013, 09:40 PM | #10 |
Welding thin walled tubing is very difficult to say the least |
02-13-2013, 09:36 PM | #11 |
Newbie Join Date: Jan 2013 Location: The Desert
Common welding wire is in the 60-70,000lb range. You can get brazing rod well into the 80,000lb range easily. Like everyone said, done right it's as least as strong as your average weld although joint design plays a big roll in final strength. Brazing also has the added bounus of being able to join dissimilar metals. One thing I haven't seen brought up much is silver soldering, which is also plenty strong (not to be confused with the solder you use to do electrical or plumbing work, totaly different) and can be done at lower tempratures. IIRC the technical breaking point between soldering and brazing is around 800 deg. so you can silver solder with a lower heat input to your parts than you can with brazing. If you have the equipment you could also tig the parts but your looking at some bucks to get started and lot and lots of time to practice. I've seen guys tig soda cans together and one guy at the shop had two pieces of aluminum foil that he welded together framed on his garage wall, so no problem with thin stuff there.
02-14-2013, 06:12 AM | #12 |
Newbie Join Date: Aug 2012 Location: grande prairie
Say a weld or braze on 2" pipe is done it will have tensile strength of not xx,xxx lb but psi or lb per sq inch. So same weld or braze on 1/4 inch done right and good quality is same strength. Braze vs weld, braze first as welding takes more skill on the smaller stuff. Surf through some of the builds on here and you can see a lot of brazing and set ups being used. As a welder for a living I have the tools and skills and have tig welded soda cans together and other thin small jobs but still get frustrated welding tig on some of this stuff. Wealth of knowledge and information can be found here though. |
02-14-2013, 06:34 AM | #13 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
this is all i use. and when asked how strong it is..i stand on my rig's nuff sed. Drail and a few rigs |
brazing vs welding: are both enough for a chassis - Similar Threads | ||||
Brazing or Welding? | realmoto | Tools, and Procedures | 11 | 02-09-2011 04:30 PM |
What is you Brazing/Welding station? | Alex.G | Tools, and Procedures | 13 | 09-12-2009 07:31 AM |
NO welding/brazing chassis | mgt714 | Tools, and Procedures | 26 | 07-20-2008 02:13 PM |
brazing vs welding | punkinhead | Newbie General | 9 | 11-06-2007 01:03 AM |
Welding/brazing help | Plays_with_Toys | Tools, and Procedures | 5 | 04-11-2006 04:27 PM |
