01-17-2013, 09:57 PM | #1 |
Newbie Join Date: Nov 2012 Location: Newcastle
| TCS Edge 2.2 Comp Rig Build Hey everybody, This thread is about my TCS Edge 2.2 Comp Rig Build. Current Parts: 1.) TCS Edge Chassis 2.) enRoute Berg 2.2 MOA Clocked Axels 3.) Integy 45 Turn Motors 4.) JR Racing z9100t High Torque Digital Aluminum Servo 5.) Integy Aluminum Servo Horn 6.) Axial Aluminum Upper Steering Rod 7.) Integy Lower Steering/Dragger Rod 8.) Axial 2.2 Wide Dished Bead Locks (Weighted) 9.) Vanquish Wheel Wideners 10.) Vanquish Aluminum Knuckles 11.) Axial Aluminum Threaded Shocks 12.) Axial Soft Semi-Droop Springs (Front) 13.) Axial Semi-Firm Springs (Rear) 14.) Hot Bodies Rovers Pink (Front) 15.) Hot Bodies Rovers White (Rear) 16.) Dynamite SpeedPack 1800 mAh 7.2v 6-Cell Ni-MH Battery 17.) Novak "The Dig" Electronic Dig Unit 18.) Tekin Racing FX-R Double ESC 19.) Axial Upper Links 20.) Axial 4-Link Suspension Setup 21.) Integy Lower High Clearance Suspension Links Future Parts: 1.) Vanquish DH Pro Comp Wheels 2.) Vanquish Bullet Wheel Weights 3.) Futaba 3pm FASST RADIO w/ receiver |
01-18-2013, 01:14 PM | #2 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: TCS Edge 2.2 Comp Rig Build
If you have two esc's whhy are you running a dig switch? Im unfamiliar with the novak dig.
01-18-2013, 07:49 PM | #3 |
Newbie Join Date: Nov 2012 Location: Houston
Dont think the FXRs have a dig mode thats why he is using the Novak Elec Dig unit. I use the Novak M2 Dig twin motor ESC and it does all the FXR and the Dig unit does in one package. But some people dont like the Novak stuff but i have never had any problems or trouble with mine! |
01-19-2013, 09:46 PM | #4 |
Quarry Creeper Join Date: May 2008 Location: Grande Prairie, Alberta, Canada
Ditch the Dig if you are planning on using a 3PMX or better radio, you can program one of the switches to cut the ESC, cleaner, faster and no Novak electronics.
01-19-2013, 10:56 PM | #5 |
Newbie Join Date: Jan 2013 Location: Auburn Ca
Dude this isn't a build if you scammed some guy on craigslist and got the complete without doing any work.
01-20-2013, 01:53 AM | #6 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
He doesn't have a radio with dual ESC mixing capabilities therefore he has to run the fxr's on the 'Novak Dig' so he can run it on a 3ch radio as a 4ch radio is not cheap.
TCS Edge 2.2 Comp Rig Build - Similar Threads | ||||
TCS EDGE Chassis Build | TXJeeper1 | Axial AX-10 Scorpion | 6 | 10-14-2010 08:12 AM |
TCS Edge build | SFT2 | Axial AX-10 Scorpion | 13 | 09-04-2010 03:32 AM |
Winner - TCS Giveaway - TCS Edge Frame - The Crawler Store | EeePee | General Crawlers | 259 | 02-26-2009 07:00 PM |
