01-22-2013, 07:06 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| Stripped Grub Screw
Accidentally stripped a grub screw on my drive shaft and cant figure out how to get it out. Any ideas? Thanks in advance, Kenneth |
01-22-2013, 07:12 PM | #2 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Re: Stripped Grub Screw
That's a bummer. Ive always had great luck using a torx bit in place of the hex driver to get out stripped ones. It will depend on how badly its stripped too. Depending on the size of the grub try a t10or t15 bit.... --Dan |
01-22-2013, 07:15 PM | #3 |
Time for a drill.
01-22-2013, 07:27 PM | #4 |
Rock Crawler Join Date: Nov 2006 Location: Holland
Metal drive shaft? First try a pen torch. Heat the surrounding material and then do what sickcivic95 advised you to do. The heat will also burn away any remaining threadlock and it will come out easily. |
01-22-2013, 07:38 PM | #5 |
Cool. Thanks for the help. Dont think i have any of those bits so i guess i will make a trip to the hardware store tomorrow.
01-22-2013, 07:54 PM | #6 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
Depending on what you have for "meat" left of the screw you can take a flathead precision screwdriver and a hammer and put a slit across the top and back it out that way or a dremel and do the same thing with a cutoff wheel
01-23-2013, 09:31 AM | #7 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
i used a small drill bit then hammered in a larger hex and it backed right out.
Stripped Grub Screw - Similar Threads | ||||
diff grub screw? | crazee horse | Axial Wraith | 4 | 01-26-2012 03:24 PM |
Stripped Hex Screw - Craftsman Screw Extractor | bigstu | Tools, and Procedures | 8 | 11-05-2011 08:48 AM |
Stripped grub screw | Highboost73 | Axial SCX-10 | 3 | 09-15-2010 03:48 PM |
Grub screw issues | ky_18b | General Crawlers | 11 | 11-28-2007 07:12 AM |
Grub Screw | RCCalifornia | Chit Chat | 4 | 09-16-2007 04:06 PM |
