Thread: SuperShafty.com "BOMBPROOF" Wraith Transmission !!!!
Old 02-08-2013, 07:16 PM   #1
Default SuperShafty.com "BOMBPROOF" Wraith Transmission !!!!
To start off I have been running my Wraith for a year now on a 3 cell lipo with a Pro 4 4000. I have also been running a SuperShafty.com top shaft with 32 pitch Robinson racing slipper and their hardened gears. Well needless to say that all gave up last weekend. Rick at SuperShafty.com told me months ago to ditch the plastic Wraith trans case, because of the chance that the bearings may let go in the plastic case. At the time my only option was to go to a ax10 style trans. Me being me I didn't want to change it. My main reason was that I didn't want to deal with needing a different rear shaft or giving up the spur cover.
So, like Rick warned my idler gear shaft and bearings ended up melting the case and let the gear go nuts destroying all the gears in the trans. Being that was my first G6 style outing I knew I needed more "BEEF". So lucky for me Rick is only 20 minutes from me. The call was made and he said he had the fix.
Introducing the SuperShafty.com "BOMBPROOF" Wraith Transmission
As you can see from the pics the stock spur cover fits even with the 32 pitch slipper setup. This particular trans was built with HR aluminum trans case and hardened steel gears. The lower gear is a hardened steel Robinson one piece unit. Of course fitted with the SuperShafty.com "BEEFY" top shaft/slipper kit. I will be honest I was a little leary about the HR parts, but after Rick showed me the pieces I was sold. The fit and finish is second to none and I look forward to trying more of their Wraith drivetrain parts
Thank you Rick for being such a top notch vendor and helping us with our insane needs for strength!!!! So get on over to SuperShafty.com and place your orders. Rick has many great parts and options available for just about any rig. The best thing is he keeps bringing more top notch goods to the table
Thanks for looking,
Farmer
Farmer is offline   Reply With Quote
Old 02-08-2013, 07:27 PM   #2
Default Re: SuperShafty.com "BOMBPROOF" Wraith Transmission !!!!
Is it in production now? Do you have a price?
twentyfootdaredevil is offline   Reply With Quote
Old 02-08-2013, 08:38 PM   #3
Wow..........Thanks for the write-up Farmer
I'm adding Pictures and prices to the site as we speak
I should have a Complete "BOMB PROOF" WRAITH section with
prices up by Sunday night
They will be in stock by Wednesday at www.supershafty.com
Best Regards, Rick
v84x4 is offline   Reply With Quote
