Red Threadlock Hi guys, just wondering why sort of Threadlock you all refer to as 'red Threadlock' because I have just looked and there is just too much choice:roll: Any help would be greatly appreciated |
Re: Red Threadlock I usually use BLUE (242) unless I never want to separate the parts again, then I'll use red (271). http://crymore.com/img/loctite-tubes.jpg |
Re: Red Threadlock Yes, do NOT use red unless you NEVER want to separate the parts. It is technically possible, but it's messy. Blue works for 99% of uses. |
Re: Red Threadlock If you use RED and want to remove the bolt or screw later, touch your soldering iron to the area for a few seconds and it'll come right off"thumbsup" |
Re: Red Threadlock Thanks a lot for your reply it was just what I wanted, I have previously used loctite 243 for everything and the tube I had has just run out and I wanted some more of that but also some red for permanently locking things and didn't know what sort I should get "thumbsup" Quote:
Thanks for the tips guys, I wouldn't put it onto anything I want to remove but the soldering iron trick sounds good"thumbsup" |
