03-02-2013, 11:00 PM | #21 |
| Re: Decided to build my 1st crawler
I'm not too hip on your transmission choice...you might want to look into an Axial or R2.
03-03-2013, 07:20 AM | #22 | |
Newbie Join Date: Feb 2013 Location: Janesville
| Re: Decided to build my 1st crawler Quote:
Cutting and drilling should be time consuming but the real trick is to make sure I get everything measured out correctly and square. I'm sure a transmission like the Axial, which was designed for crawlers, would be better than the Traxxas, but I kind of like using the parts from one truck to make another. What about the Traxxas makes it a poor choice exactly? I have the diff locked in the Traxxas so at least I will get equal power front to back from it. | |
03-05-2013, 10:25 PM | #23 |
The gearing is all wrong....I just worry that you're going to spend a lot of time getting things mounted up and then have to bust it down too make major modifications so you can install a transmission that's made for crawling.
03-08-2013, 04:09 PM | #24 |
| Re: Decided to build my 1st crawler I don't know about that. If I recall correctly the stampede trans/slash trans is 2.6:1 reduction. So is a axial trans. Wk are 2.4:1 and thy crawl just fine w big tires even.
03-08-2013, 05:49 PM | #25 | |
Haven't done much progress in the last couple days, been pretty busy with other stuff. I should be getting a 1/8 sheet of aluminum next week sometime. Once I get that I can get everything marked out on it, then drill & cut the pieces. I still haven't stopped by Ace to see if they have the hardware I want to use or if I will have to order it. I did see Harbor Freight sells some hardware kits that would be good if I didn't need metric hardware. | |
03-08-2013, 05:51 PM | #26 |
| Re: Decided to build my 1st crawler Use a small-ish pinion and it might be ok...but I'm not a fan of plastic gears, but that's just me.
03-08-2013, 07:36 PM | #27 | |
I should be able to switch it to 32p gears and pretty much gear it however I want with those. As far as plastic, I think the stock spur is plastic but everything else is metal if I remember correctly. It's been awhile since I had the trans apart last. | |
03-08-2013, 10:58 PM | #28 |
Well, there you go, that'll be a good learning experience |
Decided to build my 1st crawler - Similar Threads | ||||
Crawler King....My 1st crawler build | wyd | HPI Wheely King | 71 | 12-19-2014 09:05 AM |
1st crawler build from parts I've collected. | mr_manny | General Crawlers | 30 | 08-23-2008 09:54 PM |
1st tlt crawler build | eyerace | Newbie General | 5 | 08-06-2006 08:51 PM |
1st Crawler build ever | aussie_N_B | Tamiya Txt-1 and Juggernaut | 3 | 07-04-2006 02:15 AM |
