03-18-2013, 10:53 AM | #1 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| 3Racing winch mounting.
I wasn't sure where this question belonged, but can anyone with the 3Racing winch get me an accurate measurement of the center-to-center distance of the mounting holes, and are there 2 or 4? If there are 4 I need the same measurement from a front hole to back hole. Thanks. |
03-18-2013, 12:07 PM | #2 |
| Re: 3Racing winch mounting.
there are 4 mounting holes, sorry wont take mine apart to measure . maybe someone else will chime in.
03-18-2013, 12:30 PM | #3 |
Haha, no worries. I wasn't expecting anyone to go above and boyond for this. Hopefully someone has one laying around that they could measure up for me. The reason I ask is because I plan to get one, but for now I'm just going to mount a couple light pods, and to prevent my bumper from turning into swiss cheese I was going to space the holes for a winch in the future.
03-18-2013, 12:59 PM | #4 |
Pebble Pounder Join Date: Nov 2012 Location: Stoke on trent , England
I'll get you some sorted tonight , I only have a ruler I only have the 1/10th ones if thats ok . Jack. |
03-18-2013, 01:14 PM | #5 |
Rock Stacker Join Date: Apr 2005 Location: Visalia
It's nice to have (4) additional approximately 1/4" access holes drilled under the winch plate for access to the actual winch screws, so it can be removed easier than having to remove the which mounting plate first (those 2mm bolts / nuts can be a bear to get to at times). The 1/4" is based on the diameter of your screwdriver. Hoss |
03-18-2013, 01:18 PM | #6 | ||
| Re: 3Racing winch mounting. Quote:
03-18-2013, 01:30 PM | #7 |
if you have the stock scx bumber , the dimples in it will give you the measurements
03-18-2013, 02:40 PM | #8 |
Ok , Narrow inner holes . 2.7mm apart and width of 9mm wide outer holes 4.3mm apart and width of 8.5mm All are center to center with a ruler . Hope they're good enough dude Jack. |
03-18-2013, 02:48 PM | #9 | |
o | 2.7mm o----------------o 9mm o | 4.3mm | o---------------o 8.5mm | |
03-18-2013, 03:24 PM | #10 | |
Stupid typo's , stripping 2 cars and ordering things while measuring doesn't help . the inner winch mounts are 0--------------0 | 9mm | 0--------------0 26mm or 2.6cm outer bolt mounts are 0-------------------0 | 9mm | 0-------------------0 43mm or 4.3 cm Sorry for confusion , Let me know if you need a pic . Jack. | |
03-18-2013, 05:09 PM | #11 |
Pebble Pounder Join Date: Dec 2010 Location: Fresno
| Re: 3Racing winch mounting. I'm with my son at his karate class but if you dont have whagt you need I can get it for you in a few hours. I love my 3r winch. If you want to look at it some time before you order let me know. We also started carrying them at Hobbytown. I think there were 2-3 still in stock the other day.
03-18-2013, 06:45 PM | #12 | ||
Our HT carries aftermarket crawling winches eh? Is the crawler scene expanding over there? | ||
03-18-2013, 08:44 PM | #13 |
| Re: 3Racing winch mounting. Slowly but surely. I havent been able to work there in a couple of months due to the railroad keeping me extremely busy so I'm not up to date on it. I'm pretty sure they are going direct through Axial in stead of going through Tower but talk to Paul and he will let you know what he can get. I think he can do vanquish stuff too. I hope they can get that section to take off though. I'm going to do what I can to help with it. |
03-30-2013, 11:53 AM | #14 |
Pebble Pounder Join Date: Jan 2012 Location: Chino Hills
Does anybody have pictures or diagram for the wiring instructions or mounting to a Futaba 4PK radio
03-30-2013, 12:21 PM | #15 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Just mount it chief. |
03-30-2013, 09:54 PM | #16 |
Fronty did you get your winch or bec yet?
3Racing winch mounting. - Similar Threads | ||||
Mounting a 3racing winch? | pavel | Scale Accessories | 3 | 01-09-2009 09:58 AM |
