Thread: DIY/Homemade transfer case
Old 03-29-2013, 03:46 PM   #1
Default DIY/Homemade transfer case
I am looking for some direction on building a transfer. I've tried search but only came up with a hand full of threads. The one I am looking to do is the two pinion gears sandwiched between to steel or alloy plates.
Thanks
P.S I dont have a CNC machine
meinthe73 is offline   Reply With Quote
Old 03-29-2013, 07:37 PM   #2
Default Re: DIY/Homemade transfer case
May want to PM "bob1961" (I believe) since I know he has done "drill press transfer cases" before.
He is a member of GSRCRC, my local group.
Charlie-III is offline   Reply With Quote
Old 03-30-2013, 07:13 AM   #3
Let me know what happens now... coz i have been wanting to build one also
thanks
Zeks05 is offline   Reply With Quote
Old 03-30-2013, 01:35 PM   #4
You don't really need a cnc. Make it like a crawler chassis.
Clamp the 2 plates together and drill them in one go, that want all your holes line up.
Then use standoff to space it apart. About the most important thing is to make your you measure your gear centers correctly, so you maintain correct gear mesh
filotr14lsdude is offline   Reply With Quote
Old 04-03-2013, 01:29 PM   #5
I've made my own tranny before, same method as above, using an axial center diff mated straight to the pinion. You could do it with two center diffs though. I used flanged bearings and instead of standoffs I made a case by stacking up styrene sheet to the proper thickness and cut out the shape I needed. Drill press was my only tool.
Sent from my SCH-I605 using Tapatalk 2
MojaveMonster is offline   Reply With Quote
DIY/Homemade transfer case - Similar Threads
Homemade transfer case firefighter1211 General Scale Talk 13 06-28-2011 11:57 PM
1:18 transfer case? the_ghetto_rig General Scale Talk 1 12-25-2009 02:14 PM
GIVEAWAY-Cold Case, CRT 1.5 Transfer Case Crawln Coles Scale Accessories 215 02-02-2009 03:31 PM
DIY for bending homemade links cdl822 General Crawlers 8 07-25-2008 07:09 PM
