Thread: suspension tech questions.
Old 04-03-2013, 03:16 PM   #1
Default suspension tech questions.
I am building a 1.9 scaler currently and I have noticed that when one side of the suspension compresses the axle moves forward on that side, the rear does the same thing except the axle moves backward.....it is the same as when a stakeboard turns; when all 4 tires are on the ground and the chassis rocks side to side the axles move like the trucks on the skateboard.
Now; I know the reason for this is because of the lower links changing "length" relative to each other as the suspension compresses. My question is: will bringing the lower links closer together at the skid plate reduce/nullify this effect? I am using an ax-10 skid at the moment and would possibly switch to an SCX-10 skid to fix the problem(if triangulation does indeed solve the issue)
the reason I ask is because it is making mounting the body annoying; trying to get the wheel wells to line up and all.
Gen3_Teg_88 is offline   Reply With Quote
Old 04-03-2013, 06:47 PM   #2
Default Re: suspension tech questions.
I'd guess your links are on the short side, and/or at a fairly steep angle. Both of those will accentuate axle steer.
So, to reduce this, you need to make the links longer and more parallel to the ground.
No, mounting your links closer together at the skid won't help. Might even make it worse.
Manning is offline   Reply With Quote
Old 04-03-2013, 07:54 PM   #3
the front links are pretty short but the rears a quite long and they do it even more so.
Old 07-06-2018, 02:50 AM   #4
It is because Your top links have more Horizonte angle then the bottom I think.
Old 07-06-2018, 02:53 AM   #5
So yes I think moving the lower links closer to the inverse angle to the upper links would help.
Old 07-06-2018, 08:34 AM   #6
Is it possible your driveshafts have reached their compressed minimum length, (I.E., bottomed out) and are then pushing the axle back, wheel back as the suspension tries to fully compress/articulate? I had this happen on a rig and resolved by trimming back the driveshaft to allow for full compression of the suspension.
mewalsh100 is offline   Reply With Quote
Old 07-07-2018, 08:08 AM   #7
How long are your front / rear links?
How long are your shocks?
How much sag do you have?
number9 is offline   Reply With Quote
Old 07-13-2018, 06:06 AM   #8
Its geometry. moving your links closer together wont change it.
On any solid axle connected by links, even 1:1 vehicles, the axle doesn't move straight up and down, it moves in an arc determined by the length of the links. The further you get from the links being parallel to the ground, the more pronounced it will get.
One of the issues jeep owners run into is when lifting solid axle jeeps without changing to long arms, at higher lifts tires are noticibly closer to the rear of wheelwell in the front and the front of the wheelwell in the rear. Not a huge problem unless you have OCD, but its there. As the angle of the links gets steeper, it gets more pronounced. Thats the whole point of changing to long arm suspension on 1:1 scale rigs.
dacaur is offline   Reply With Quote
Old 07-13-2018, 07:48 AM   #9
We do know this is a 5 year old thread, right?
The OP must have solved his issue because he hasn't been on here in 2 years.
svt923 is offline   Reply With Quote
Old 07-13-2018, 08:29 AM   #10
DukeMinnix is offline   Reply With Quote
suspension tech questions. - Similar Threads
Anti Squat and Suspension Tech Cole82 General Crawlers 402 05-16-2015 09:24 PM
(HH) Tech Questions and Customer support thread JohnRobHolmes Holmes Hobbies 3483 02-05-2013 09:08 PM
suspension tech 101.... short course vs. crawler mudn_1 General Crawlers 18 10-05-2012 06:12 AM
Tech questions-- Slipper clutch, shocks, tire foams.. FOXX Losi Mini-Rock Crawler 11 01-31-2012 08:33 PM
