04-20-2013, 05:59 AM | #1 |
Newbie Join Date: Jan 2013 Location: Oil City
| AX-10 Trans and a VXL-3S???
Anyone know if a stock Axial AX-10 Trans can handle a VXL-3S System? Thought it might be fun to try.
04-20-2013, 08:51 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
| Re: AX-10 Trans and a VXL-3S???
Not in stock form but if you replace the plastic gears with steel Robinson or hot racing gears and convert to 32p spur and pinion gears then it will handle a vxl all day. I run one in my wraith and followed that recipe without issue.
04-20-2013, 10:28 AM | #3 |
Pebble Pounder Join Date: Jul 2007 Location: Oveido, Florida
I run all Robinson racing internal gears carbide steel spur and Robinson racing absolute pinion still 48p and have no problems with my sv3 and castle 1410 4 pole 2400
04-20-2013, 11:14 AM | #4 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
I am with Diesel kawboy...... Replace plastic gears and its on and popping time. I have this combo in 2 rigs I own and no problem. Just make sure you have strong enough drive lines !!!!
04-20-2013, 04:34 PM | #5 |
Drive lines and all links are aluminum and hardened steel. Thank you all for the info. Have to check out the steel gears for trans then. cold make a nice tough truck or foff setup. thanks again.
AX-10 Trans and a VXL-3S??? - Similar Threads | ||||
VXL trans spur adapter? | hawnmt | General Crawlers | 1 | 03-31-2009 02:14 PM |
