04-21-2013, 03:17 PM | #1 |
Rock Crawler Join Date: May 2004 Location: delavan
| ridgecrest to wraith
i bought a used wraith a while back and was told it was a ridgecrest converted to wraith it uses a ridgecrest trans. are the internals the same as wraith i want to order steel center diff for it and want to make sure i get the correct one thanks
04-21-2013, 05:05 PM | #2 |
| Re: ridgecrest to wraith
The gears are the same but the outdrive shafts are different. When a AX10 transmission is put into a Wraith, a longer outdrive shaft is sometimes used to make drive shaft angles work. You will need to check what is in your rig. If you do have AX10 stock outdrive shafts then you could use RPP#1542. If not, then you could use the HR Steel gears and reuse your output drives. Hardened steel gear set for the AX10. - Super Shafty |
ridgecrest to wraith - Similar Threads | ||||
ridgecrest or wraith | paul j | General Crawlers | 7 | 01-12-2013 10:50 PM |
Ridgecrest to Wraith? | R|M|D Photography | Axial AX10 2nd-gen | 2 | 10-08-2012 04:00 PM |
ridgecrest or wraith | bigred94 | Axial AX10 2nd-gen | 38 | 08-15-2012 11:18 PM |
wraith vs ridgecrest | bigred94 | Axial Wraith | 0 | 06-16-2012 09:43 AM |
