05-16-2013, 12:30 PM | #21 | |
Pebble Pounder Join Date: Apr 2013 Location: in a house
| Re: RC Crawler Differential Survey Quote:
Locking differential - Wikipedia, the free encyclopedia | |
05-16-2013, 12:40 PM | #22 |
Have you ever looked at Tamiya high lift axles?
05-16-2013, 02:09 PM | #23 |
| Re: RC Crawler Differential Survey Looks like they just have an open diff but I couldn't find a good description so they might be lockable. Did come across this.... All Axle Dimension / Width / Gear Ratios - Scale 4x4 R/C Forums which is a little off topic but it's interesting to see the various axles that are or have been available. |
05-17-2013, 02:24 AM | #24 | ||
Quarry Creeper Join Date: May 2009 Location: India
I am considering a situation where a vehicle is running straight.Then it takes a right turn and after the turn is completed, starts moving straight again. I have divided this whole process in a time frame of couple of seconds. I will try to explain what happens at every second of time. I might need some further explanation from you. I am still thinking further...... Last edited by wings_of_fire; 05-17-2013 at 02:36 AM. Reason: Resizing image.... | ||
05-17-2013, 02:26 AM | #25 |
| Re: RC Crawler Differential Survey Seems like photobucket has reduced the image size... does anyone have a solution to that ----------------------------------------------------------- Got images resized... Last edited by wings_of_fire; 05-17-2013 at 02:35 AM. |
05-17-2013, 03:01 AM | #26 |
I haven`t changed the drive shaft rpm. We are considering the drive shaft rpm of 150 to be stable in all situations. To keep the drive shaft rpm stable, the rotational power coming from the traction wheel cannot go through the crown gear to the drive shaft increasing its speed over 150 rpm. So this energy should have been transferred to the slip wheel through the differential pinion gears. But then the slip wheel rpm will increase............ So what exactly happens? The image under is just a thought and should not be considered right until proven. I also have not added the vectors for the traction wheel. Last edited by wings_of_fire; 05-17-2013 at 03:04 AM. |
05-17-2013, 06:48 AM | #27 |
| Re: RC Crawler Differential Survey |
05-17-2013, 06:57 AM | #28 | |
And ps wings... You should go over your math again. | |
05-17-2013, 08:08 AM | #29 | |
And regarding the math thing, did you say that because one of the vector is pointing towards the differential when it should be actually pointing towards the wheel? | |
05-17-2013, 08:38 AM | #30 |
| Re: RC Crawler Differential Survey No, I'm talking about the rpm changes in the rear wheels. From your first picture we can determine that we have a 3:1 ring and pinion ratio. So for example in your second picture if you are turning at an angle that makes the outside tire turn at 55 rpm then we can determine that the inside tire would be rotating at 45 rpm, not 50 as indicated.
05-17-2013, 09:20 AM | #31 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
I have had a few venom creepers. Take their design but run 12 pins into 12 holes through a steel diff case and into a side gear and you would be good. Being able to open the rear up while using dig would be wonderful. The problem with the original venom design is too few engaging pins, they only used 3. They bent, elongated the 3 holes in the plastic diff case and never stayed locked. Mine all got JB welded. Make it manual and/or servo actuated.
05-17-2013, 12:45 PM | #32 |
| Re: RC Crawler Differential Survey You did its true but it just seemed part of your description then. Now its clear. This sentence from the wikipedia link I posted helped. "They (automatic (un)lockers) will never allow either wheel to spin slower than the differential carrier or axle as a whole, but will permit a wheel to be over-driven faster than the carrier speed" And here's a u choob on the Eaton NoSpin "Detroit Locker" as an example Detroit Locker - YouTube |
05-17-2013, 11:00 PM | #33 | |
I will prefer electronically actuated Thanks for outlining the technical problem and sugession | |
05-17-2013, 11:34 PM | #34 | |
And I was confused about the word u choob in your earlier post..... | |
05-18-2013, 01:01 AM | #35 | |
When turning, the outside wheel wants to go faster and is allowed to but the inside wheel retains the carrier speed. This is why you get more tire wear and why you can lose control on ice. The inner wheel can break traction since it's forced to rotate possibly faster than it can without braking traction. It is also why you get under-steer when this is used on front axle. The inner wheel is forced to rotate faster than it should to follow the turn and so retains traction going forward resisting the turn. The numbers will depend on the axle ratio but assuming 3 to 1 then the axle is turning at 150 and doesn't change then the inner will never fall below 50. The outer will rotate at 50 + until the turn is complete and then it will return to 50. | |
05-18-2013, 06:20 AM | #36 | |
On a side note, you could do a face spline design and get more then 12 splines in there and rather then engagement pins it would be an engagement plate. with matching splines of course. Last edited by Exocaged; 05-18-2013 at 06:23 AM. | |
05-20-2013, 03:02 AM | #37 | |
The one I'm referring to does most definitely allow the inner wheel in a turn to run slower than the diff carrier, after the outer wheel begins to spin faster than the carrier and thus open the lock. While the lock is open it's acting like a regular (open) differential. | |
05-20-2013, 05:45 AM | #38 | |
05-20-2013, 07:16 AM | #39 |
Newbie Join Date: Aug 2011 Location: Bristol, England
I think this would be a cool feature to have, depending on the vehicle. My x-crawler has a top speed of about 3mph thanks to gearing and 55t motors, so a working diff is irrelevant. But take the TLT I've just bought as a semi-scaler - I'm keeping that as a cross-over vehicle. I guess you could say it's a small imitation of something like the Traxxas Summit, a truck that can speed around and crawl a bit too, and that's not an easy thing to pull off well. Having diffs that can lock and unlock is kinda essential, as with real vehicles that have to do the same thing. Traxxas' solution is cool, but the Summit is a pricey truck and not everyone considers their system a complete success. Being electronic means that much more to go wrong, especially at smaller scales. In an ideal world I would like a mechanical action on the diff itself. You could then open front, rear or both diffs etc. and with no need to worry about doing that on a radio. I wouldn't be that bothered about losing the ability to do it on the fly. Tamiya used to make XB models with a two-speed transmission selector on the axle itself - something like that. Good luck with the project. |
05-21-2013, 12:22 AM | #40 | ||
Actually, cost and benefit aside the Detroit Locker is compact and elegant enough that it might scale down quite well. Detroit Locker - YouTube I don't think the same could be said for the "lunchbox/Lock Right/Aussie" style since it relies on a single central pin to split some dog toothed gears which wear fast at 1:1 scale. Lock Right Locker - Part 1: How it works [HD] - YouTube Project-JK.com - Jeep JK Wrangler Resource » Dynatrac Presents - Lockers 101 | ||
RC Crawler Differential Survey - Similar Threads | ||||
Survey - would you consider buying a US$130 rock crawler? | wildthing | General Crawlers | 23 | 05-22-2013 09:16 AM |
Got some time? Want to help with a survey? | JohnRobHolmes | Chit Chat | 5 | 02-22-2009 09:40 AM |
college english class RC crawler survey | Del Montess | Chit Chat | 44 | 01-17-2009 11:51 PM |
2.2 Crawler Wheelbase / Width Survey | ARC MotorSports | Tamiya TLT Crawlers | 16 | 05-13-2005 11:33 AM |
