06-05-2013, 05:58 PM | #1 |
Rock Stacker Join Date: May 2012 Location: Toronto
| Tamiya cc01 rear diff grinding
My tamiya cc01 makes a bad grinding sound in the rear diff. Its drives fine with only front wheel drive but when i put the drive shaft back on it grinds again. Ive checked the rear diff gears and ive cleaned,greased them but i cant tell if they are striped or not. And i know its the rear because all the other gears work and look new ! Please help me |
06-05-2013, 06:09 PM | #2 |
| Re: Tamiya cc01 rear diff grinding
Did you shim the pinion? Often times that is what the grinding is caused by. Replace the gears if the gears are worn, or broken.
06-05-2013, 08:46 PM | #3 |
What does shim the pinion mean ? I have replaced them but im scared i didnt get all the dirt out and its really hardto find the part i need
06-05-2013, 09:48 PM | #4 |
Shims are to adjust gear mesh. The pinion gear is small one in the axle, you put shims, (i used .5mm) put them on the shaft between the bearing(bushing) and pinion to push the piniom into the big gear(ring).
Tamiya cc01 rear diff grinding - Similar Threads | ||||
Spider gears in rear diff (aka losing the rear locker) | Sethmetal | Vaterra Twin Hammers | 2 | 02-26-2013 11:57 PM |
tamiya diff lock and shaft front or rear? | cydog510 | Tamiya CR-01 | 4 | 03-29-2011 11:24 AM |
tamiya hummer rear diff lock? | Kur | Newbie General | 15 | 12-02-2005 08:55 PM |
Mean grinding coming from the rear diff.... | Vu14TJ | XTM Crawler | 6 | 09-01-2004 03:52 AM |
