06-07-2013, 05:55 PM | #1 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
| Gear lube
Can anyone link me to buy a good gear lube? I rebuilt my axles and want to lube it
06-07-2013, 07:18 PM | #2 |
Rock Crawler Join Date: Feb 2005 Location: Oak Ridge
| Re: Gear lube |
06-07-2013, 07:21 PM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Gear lube
Hey Natski I've been using a marine grease...it's green, sticky as hell and waterproof. Comes in a 16 OZ tub and can be found at your local auto parts store..about $7 and I've been re-building my axels lately and this stuff is still on my gears ...can't say you'll find anything better for the price. |
06-07-2013, 11:23 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Generally you can use any grease that you would use on your every day vehicle. I personally use a grease called krazy grease. It's green and tacky as h**l also very good water grease. Sent from my GT-I9100M using Tapatalk 4 Beta |
06-08-2013, 01:03 AM | #5 | |
| Re: Gear lube Quote:
I use a product called SuperLube, have been since the '80s. Found out a local Ace Hardware carries it. | |
06-08-2013, 02:20 AM | #6 |
Newbie Join Date: Apr 2013 Location: Aus
| Re: Gear lube
I use marine grease in my diffs/trans. cheap as chips
06-08-2013, 02:28 AM | #7 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: Gear lube
red and tacky seems o hold up better than the normal auto grease. And because it stays in place better - less is more.
06-08-2013, 06:53 AM | #8 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Gear lube
try " speed grease", waterproof . 3 bucks for a tub of it and you dont have to coat the entire axle with it ( newbie thing ,they dont know ant better and it just makes a mess) . just cover the gears with it and your good to go and it lasts forever. use it in all my rigs for several years without issue.
06-08-2013, 11:34 AM | #9 |
Pebble Pounder Join Date: Apr 2013 Location: in a house
| Re: Gear lube
If your axles/gears have plastic parts make sure to use a lube that is compatible with plastic. Petroleum based lubes can weaken plastic parts.
06-09-2013, 12:00 PM | #10 |
Newbie Join Date: Sep 2009 Location: Maui/Hawaii
| Re: Gear lube
should you grease the outer bearings to protect it from water getting in the actual ball bearings inside, like on the rear lock outs, chubs and knuckles? or the bearings are pretty well sealed? |
Gear lube - Similar Threads | ||||
1/8 buggy gear lube | racerfred | Non Crawler RC's | 1 | 08-07-2010 01:06 PM |
axle gear lube, what do you use? | tombs | Redcat Crawlers | 2 | 04-14-2010 02:59 PM |
gear lube | gearstripper | Newbie General | 19 | 01-28-2010 01:20 PM |
Gear Lube!!! | JeeperoManiako | General Crawlers | 3 | 04-14-2006 12:32 AM |
Gear Lube? | PastryLikeDood | General Crawlers | 3 | 03-30-2005 06:25 PM |
