07-13-2013, 10:29 PM | #1 |
Pullman Crawler Join Date: Jul 2007 Location: Pullman
| Worm and Worm Gear Question
Okay guys, I'm in the middle of my TJ Build and I want to make up a working Steering gear (Steering box). Something that will be to "scale". I would like it to be ran from the steering column and really turn the wheels. My plan is to have a servo under the dash the will be running the steering column. I am having a hard time finding a set of gears that will work for it. I need a hardened steel Worm and Worm gear set that will be the base to build the box around. My problem i am having is it is hard to find a set of gears small enough and when i do find some, they are out of stock. I was hoping that some of you guys know some site that i don't that have something that will work. This is the best I can find, but the worm is still bigger then i would like. http://sdp-si.com/ss/pdf/81001213.pdf What do you guys think? any Ideas? Thanks for whatever help you can give. |
07-13-2013, 11:57 PM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: SW Iowa
| Re: Worm and Worm Gear Question
I've been thinking about this too for a Jeep tuber I'm working on for my stepson. But I'm not sure where to find gears or how feasible it really is. Might be better to just use a bell crank.
07-16-2013, 12:43 AM | #3 |
Rock Crawler Join Date: May 2013 Location: Dallas
Losi Micro Trail Trekkers use a brass gear and steel worm. These are probably small enough to accomplish your task but still strong enough for what you need. IIRC they're 16:1 ratio or pretty close too so you'll get quicker steering than even the best ratio of the gears you posted.
07-16-2013, 02:39 AM | #4 |
Quarry Creeper Join Date: May 2009 Location: India
This should solve your requirement... I think this company is the best when it comes to availability of small gears.... But Horrible price HPC Gears Home page Last edited by wings_of_fire; 07-16-2013 at 03:35 AM. |
07-18-2013, 08:40 AM | #5 |
Thanks for the information guys I will take a look.
Worm and Worm Gear Question - Similar Threads | ||||
HD Worm gear issues...Still?? | maxxflip | Team Losi Comp Crawler | 25 | 04-06-2013 05:46 PM |
worm gear?? | ontriocrawler | Team Losi Comp Crawler | 8 | 04-01-2011 04:49 PM |
New worm gear question | Creepy Crawler | Team Losi Comp Crawler | 23 | 11-03-2009 10:34 PM |
worm gear | Skyjacker56 | General Crawlers | 4 | 12-01-2008 06:12 PM |
