wraith trans gear I think I have striped the plastic gear in my transmission where could I get a metal gear to replace it I don't need the whole set I just need the bigger one |
Re: wraith trans gear Did you look on Axials site for replacement parts? I know they have direct replacement as well as upgraded XR-10 bits on there. |
Re: wraith trans gear You can get an upgraded output gear for the Wraith transmission that is metal. Robinson Racing Hardened Steel Bottom Diff Gear Wraith |
Re: wraith trans gear Quote:
My Wraith #2 has the HR gear set with a Roc412 3100. I have broke a lot of other stuff but not the transmission. |
Re: wraith trans gear Ok thanks I am going to buy the hot racing gears but do they have the same amount of teeth as the stock gears |
Re: wraith trans gear Yep, they are a direct replacement kit. Same gearing. |
Re: wraith trans gear Where could I get just the spur gear I need a metal 80t and was wanting to know if the smaller idler gear I think thats what it is called if the one that comes in the wraith is steel or hard aluminum |
Why do you need a metal 80tooth? And no the wraith comes with plastic gears with a metal upper gear. |
Re: wraith trans gear My plastic one striped out badly and don't want to get another plastic just to strip that one and the gear that comes in it is 80t so that's what I need do you know a website where i could get it |
If you shredded a plastic 48p go to 32pitch. Gearing about 13/56 is the sweet spot. |
