Thread: What other springs fit pro-lines slash shocks
Old 09-23-2013, 10:05 AM   #1
Default What other springs fit pro-lines slash shocks
Does anyone know. I need some other spring rates.
Thanks.
The Doc is offline   Reply With Quote
Old 09-23-2013, 01:44 PM   #2
Default Re: What other springs fit pro-lines slash shocks
IIRC, MRC springs do.
JeremyH is offline   Reply With Quote
Old 09-23-2013, 02:04 PM   #3
The slash version are the larger bodied shocks. In that case just about all of the springs we use to run like the Losi Golds, White, Red, Grey, etc. should work.
ittybitty is offline   Reply With Quote
Old 09-23-2013, 08:07 PM   #4
Thanks Jeremy. I will look at those also.
Cool, I have some losi's from my 10scte. I never check them I just thought they were bigger. Thanks.
Old 09-24-2013, 04:59 PM   #5
the scte springs are much larger in diameter. the associated buggy springs are the correct size just use the ones for the rear shocks, which are longer.
envious8420 is offline   Reply With Quote
What other springs fit pro-lines slash shocks - Similar Threads
Pro-line scaler shocks and mini-t springs??? EDGE General Crawlers 2 01-29-2013 10:19 AM
Springs to fit over std shocks? andrwassht Tamiya CR-01 2 03-26-2010 03:01 PM
Internal springs that fit inside the stock shocks??? RCholic Axial AX-10 Scorpion 5 10-05-2007 06:15 AM
