10-01-2013, 07:24 PM | #2 |
Quarry Creeper Join Date: Apr 2013 Location: GODS COUNTRY,LOUISIANA
What's going on with them boss I have a set
10-01-2013, 07:58 PM | #4 |
There should be a c clamp to hold that in place
10-01-2013, 08:12 PM | #6 |
Correct same here
10-01-2013, 08:12 PM | #7 |
Did you shim your pinion gear
10-01-2013, 08:18 PM | #8 |
Newbie Join Date: Jul 2013 Location: A house
Yep.. If I were. To put it in then pull on it sometimes it feels like it's locked in there then if I wiggle it a little it comes out... I can post pics of everything I have.. Maybe I'm missing something. Sent from my iPhone using Tapatalk - now Free |
10-01-2013, 08:37 PM | #10 |
Hmmm hold on let me loom at mine I have one torn apart already
10-01-2013, 08:45 PM | #11 |
Here's mine and by the way not to spoil your excitement these axles are the $%&*iest axles made mine grenaded within 45 minutes of a G6 replaced them with my stock axial scx10 axles to finish the comp .... anyways I Dont see how the gear could come off the shaft mi e looks like a solid piece
10-01-2013, 08:49 PM | #12 |
Yep one piece
10-01-2013, 08:52 PM | #14 |
No problem boss man good luck I hope you get to enjoy them more than I did :thumbup:
10-02-2013, 07:48 AM | #16 |
| Re: T Rex 60's problem Yes, NS35's gears look worn out, thus the "wings" on the large OD of the gears. This can lead to opening the gear mesh between the pinion & ring gear leaving the rig motionless. I think new parts are in order. bmillers gears look OK. Spares/upgrades... T-Rex 60 Axle Parts Last edited by Charlie-III; 10-02-2013 at 07:52 AM. |
10-02-2013, 10:31 PM | #17 |
Quarry Creeper Join Date: Nov 2012 Location: chicago
Your pinion gear came apart. I had the same happen on mine. They are ten bucks on. Rc3wd If they have them in stock |
10-03-2013, 06:48 PM | #18 | |
10-03-2013, 08:23 PM | #19 | |
| Re: T Rex 60's problem Quote:
Yeah, I had just realized that. The problem is though I haven't used these axles at all.. So i'm going to email rc4wd and see if they can send me a new output shaft. Thanks for your responses guys. | |
10-06-2013, 01:47 PM | #20 |
Moderator Join Date: Jan 2004 Location: chicago
tlt/highlift pinions will work with the trex's. i twisted off the pinion outputs from the hardened rc4wd gearsets on a regular basis when i tried using the trex axles on a comp rig. |
