10-10-2013, 08:43 PM | #21 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Unavailable Parts
here's a long shot but, Quicksand winches!!
10-10-2013, 08:43 PM | #22 |
RCC Addict Join Date: May 2013 Location: York, PA
MRC axles have no aftermarket lockers beyond the HR aluminum one and it doesn't have a good reputation. The Losi lockers are getting hard to find. Options to run a spool that would fit axial stuff for xr and lcc modded mini's. Then we could run cut down uni's up front and straight shafts rear. Set the tabs back on the locker so a shim kit would be required to run the stock pinion, but give the option to change the shim pack to run different overdrive/underdrive pinions without shaving the housing to shim the whole thing over which causes engagement issues with the axle shafts. Being able to move the ring gear independant of the spool would help eliminate shimming/slop/gearing issues many of us have. That would be awesome. Also, better heavy duty extended outputs to run larger spur gears/ drive shafts, like Crawler Innovations has for the AX10. My 66t spur rubs the shaft up front but I love the torque it provides. The trans lockers are also hard to find so lets eliminate them with something never offered before........ Possibly allow guys to run something similar to the Maxx shaft upgrade. Wild boar or summit etc. I'm not sure though, haven't put much thought into it.......lol |
10-10-2013, 09:46 PM | #23 |
Rock Crawler Join Date: Mar 2009 Location: Alvin,Texas
Jeremy H's sideburns out of delrin , so they dont get hung up in the rocks . |
10-12-2013, 09:27 AM | #24 | |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Unavailable Parts Quote:
X2 sounds good! . | |
10-12-2013, 09:30 AM | #25 | |
Not to be an a$$ but RC4wd just started offering a Hand Bros CMS replica. Chassis Mounted Steering Servo Kit with Panhard Bar for Axial SCX10 . | |
10-12-2013, 10:39 AM | #26 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
No according to there website they engineered it. Mad props for another vendor with no ethics. They wonder why there reputation sucks.
10-12-2013, 11:50 AM | #27 | |
HAHAHA!!! Change a hole location and BAM!!! engineered. Whatever helps them sleep at night... I am sure it is as good as the rest of their cheap Chinese quality stuff. . | |
10-12-2013, 12:47 PM | #28 |
I miss the non-slipper input shafts for the AX-10 transmission. Iv'e seen a vendor offering a Ti version ( supershafty??) but I'd just like the inexpensive and bullet proof Axial version. The Tamiya suspension stays ( brackets) were great for scratch built frames, they just are almost impossible to find in quantity anymore. What else..... I know- the Stage3Racing spools, they were relatively inexpensive and damn near indestructible. Too bad they just blatantly copied someone else's design and called it "theirs". |
10-12-2013, 06:14 PM | #29 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
[QUOTE=BigSki;4509712]I miss the non-slipper input shafts for the AX-10 transmission.QUOTE] Locked up RC sells one Slipper Eliminator Kit - AX10 SCX10 Wraith |
10-12-2013, 06:17 PM | #30 |
| Re: Unavailable Parts |
10-12-2013, 06:18 PM | #31 |
Sure would like to see an over/underdrive transfer case for all the axles out there that don't have those gearsets avail at the axle.
10-12-2013, 07:16 PM | #32 | ||
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
Not to worry, I know where my cms will be purchased from | ||
10-13-2013, 12:26 AM | #33 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
10-13-2013, 01:00 AM | #34 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
I really hope someone can bring back Quicksand winch I knew many people are waiting for this winch so bad.... |
10-13-2013, 03:17 PM | #35 | |
| Re: Unavailable Parts Quote: | |
10-13-2013, 04:03 PM | #36 | |
Rock Crawler Join Date: Jan 2007 Location: UK
Get your facts straight before posting crap. | |
10-13-2013, 05:41 PM | #37 |
My comment still stands
10-13-2013, 06:12 PM | #38 |
I wish I could still find a metal Hi-Lift jack. lol
10-13-2013, 06:24 PM | #39 |
I remember being able to by Kyosho Magnetic mayhem 22x1 550 motors for $20 a pop. The rest of the "mad science" series of motors were pretty good as well. Last two NIB ones I found, almost a year ago, were reverse rotation and $35 a piece. |
10-14-2013, 10:49 AM | #40 | |
RCP CRAWLERS Join Date: Nov 2007 Location: Upland CA
sure makes it hard to put the time and effort into a new part | |
Unavailable Parts - Similar Threads | ||||
why vanquish diff locker VPS05990 are unavailable to us all websites | jclc | Axial Wraith | 6 | 09-01-2013 03:13 PM |
