10-15-2006, 08:48 PM | #1 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
| O-ring
Which size o-ring do you replace th belt with in the front and rear axles?
10-15-2006, 08:56 PM | #2 | |
Quarry Creeper Join Date: Feb 2006 Location: In da 801 "AKA Tiny"
10-16-2006, 09:33 AM | #3 |
Newbie Join Date: Sep 2006 Location: mo-town
i used a 1-13/16 for the front i tried using a 1-7/8 and it seemed a little too tight for the back so i went to a 2" also in the back
10-25-2006, 03:32 PM | #4 |
Thank you
10-25-2006, 03:36 PM | #5 |
RCC Addict Join Date: May 2006 Location: Aroostook county
i found that all replacing belts with o rings does is break things, go ahead and take the stock pullies and rough them up with sandpaper
10-26-2006, 12:09 PM | #6 |
Newbie Join Date: Oct 2006 Location: Red Lion
Modifying the stock belts is a good idea. And of course it will keep the other things working properly as it did before. But the o-rings seem to be working to, as long as you do not overwelm the electronics with an o-ring thats too small. 1 7/8" is fine for the front and 2" is fine for the back. It will give you some extra grip but should still slip when it has to. But still, don't force the crawler if it won't go, thats never good :-(
