08-13-2014, 03:47 AM | #21 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
| Re: Ebay transfer case??
I have two of these t-cases from Ebay and I've run each of them for a year without issue. They are so simple that there isn't much that can fail, but then I don't beat the crap out of my scale rigs. As I recall it did take almost a month to get them. |
08-18-2014, 09:12 AM | #22 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
its definitely a rip off of the GCM cases. but when something is made correctly someone if bound to copy it. take it as a compliment GCM. i have 3 of the GCM transfer cases. i have never had an issue with them, and have had them on one truck for over 3 years, and its never failed. one trick to reduce any chance of slop: take all the grub screws or set screws if you call them that, and grind the base flat, this will create a much better mechanical mesh with the very large flat spots on the GCM cases. no slop at all after years of use. |
11-10-2014, 06:26 AM | #23 | |
Newbie Join Date: Feb 2014 Location: Munich
| Re: Ebay transfer case?? Quote:
did the transfer case accomplish the task? Would you recommend it? | |
11-10-2014, 10:28 AM | #24 |
Nice alternative. High prices breed clones.
11-10-2014, 03:12 PM | #25 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
| Ebay transfer case?? |
11-10-2014, 06:09 PM | #26 |
Moderator Join Date: Jan 2004 Location: chicago
spend the money, get the gcm. loctite the grubscrews in the pinions and never worry about making the wrong choice. i think i might put my chinese tcase in my 12lb c2 and see how bad i can break it just to prove that the gcm is better. ;) |
11-10-2014, 08:58 PM | #27 |
| Re: Ebay transfer case?? |
11-13-2014, 06:31 PM | #28 |
Rock Crawler Join Date: May 2012 Location: Washougal
Hate to say it guys but I have been thrashing on one of these for over a year. Haven't even had to replace the bearings. Just an fyi, the case is slightly smaller than the GCM. |
11-18-2014, 08:31 AM | #29 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
......... And Sam drives like an animal........Rarr
Ebay transfer case?? - Similar Threads | ||||
can anyone ID this transfer case? | brianw | General Scale Talk | 6 | 08-11-2012 04:26 PM |
1:18 transfer case? | the_ghetto_rig | General Scale Talk | 1 | 12-25-2009 02:14 PM |
GIVEAWAY-Cold Case, CRT 1.5 Transfer Case | Crawln Coles | Scale Accessories | 215 | 02-02-2009 03:31 PM |
