11-29-2013, 06:49 PM | #1 |
Newbie Join Date: Aug 2013 Location: Chippewa
| Is it possible to mold your own gears?
This might be an odd question or thread in the wrong spot sorry I'm a noob. I know people use mills, lathes, and CNCs to make custom RC parts but I was wondering could you take a Spur and make a mold of it then get some aluminum or other metal and melt it down and pour it into the mold and make a metal spur. If the mold was a little off you could clean up the rough places with a Dremel or sand paper. But has anyone done it or attempted it? I have a furnace I made a while back it is made of a sand and Plaster of Paris mixture and works great. |
11-29-2013, 06:58 PM | #2 |
Pebble Pounder Join Date: Oct 2013 Location: Stockton
| Re: Is it possible to mold your own gears?
I don't it would be very strong like a machined part,unless it was some sort of ductile steel
11-29-2013, 07:06 PM | #3 |
So your saying it could work? In theory it should.
11-29-2013, 07:08 PM | #4 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
Anything is possible. It is an issue of time and cost in my opinion.
11-29-2013, 07:11 PM | #5 |
If you have gone as far as to build a furnace than you already know its possible.
11-29-2013, 07:14 PM | #6 |
Quarry Creeper Join Date: Nov 2012 Location: Paxton
I would say unless you are going to start mass producing them to sell, it's probably not worth your time. when you could just buy a metal gear from a store already. not saying you can't do it. just my 2 cents.
11-29-2013, 07:27 PM | #7 |
Quarry Creeper Join Date: Nov 2013 Location: Huntsville
You can usually get precision component manufacturers like W. M. Berg to manufacture custom gears for you in the material of your choice. I got some estimates on a specialized gear that I designed in grad school and the prices were pretty reasonable. WM Berg: Part Customization and Engineering Services |
11-29-2013, 07:41 PM | #8 |
I never thought to go to a website that makes it but the Spur I'm trying to remake is a Spur that has no aftermarket sellers. The stock one is bad because just the heat of the motor softens it to a point were every time you use it, it takes all the teeth off. Before I attempt to do this does anyone know if there is any aftermarket spurs for a Vaterra Glamis Uno?
11-30-2013, 07:04 AM | #9 |
| Re: Is it possible to mold your own gears? |
11-30-2013, 09:06 AM | #10 |
Quarry Creeper Join Date: May 2009 Location: India
That One Guy, The mechanical properties of aluminium do not suit heavy load gear applications. There are various process in which gears are manufactured 1] Machining a stock 2] Casting molten metal and then machining 3] Pressure Die casting 4] Vaccum casting 5] Forging stock to a rough shape of the gear and then machining it to finish 6] Gear profile rolling 7] Injection moulding plastic gears Then there is the heat treatment process for metal gears which is absolutely important. I know you are willing to cast gears using your furncae, but there will be metallurgical issues that will create a weak cast aluminium. In your furnace there is a high possibility that unnecessary impurities will get mixed into the aluminium changing its material composition. The cast gear probably won't have the tensile strength that an induction furnace coupled with pressure die casting machine can give. I would say, if you can cast brass and machine its gears then those will work fine with low levels of load and not loose the involute profile on the gear teeth. But you do the same with aluminium and you will loose the gear tooth profile within no time. Brass would need a higher melting temperature and will be heavy. Here is a beautiful video showing how aluminium gravity die casting is done as well as pressure die casting in the first few minutes. |
11-30-2013, 09:13 AM | #11 | |
| Re: Is it possible to mold your own gears? Quote:
You will fail with it, but you should try it and fail. You will learn much better than experience shared with words.. | |
11-30-2013, 09:30 AM | #12 |
Oh alright. CHUD I need a spur not a ring gear but something along those lines. I guess Ill buy a aftermarket spur and maybe mod it a bit to make it work. Thanks for the feedback guess. You saved my from spending a lot of time to fail.
11-30-2013, 12:12 PM | #13 | |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
11-30-2013, 03:08 PM | #14 |
What about using the center of your stripped spur and bolting a more standard spur to the face of it?
11-30-2013, 09:11 PM | #15 |
12-01-2013, 11:11 AM | #16 | |
RCC Addict Join Date: May 2013 Location: York, PA
I'll take your word for it vs trying it myself. | |
12-01-2013, 12:04 PM | #17 | |
I learned what I know because of intentional failures. Occasionally, conventional wisdom is based more in ignorance. Have some fun, stoke up that furnace, learn why cast gears are difficult to produce. You could make some pretty jewelry in the process | |
12-01-2013, 12:10 PM | #18 | ||
if that doesnt get you motivated i dont know what will | ||
12-24-2013, 01:44 PM | #19 |
Quarry Creeper Join Date: Nov 2006 Location: The Styrene Dungeon
12-25-2013, 10:43 PM | #20 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
I have molded many custom gears and parts including spur gears with this stuff IE-3075 Polyurethane it is stronger than most injection molded plastic spurs and parts you get at the local hobby store. It can be hand mixed and molded at home with a silicon mold and if you really want to make sure its strong put it in a vacuum chamber and make sure all the air bubbles are out. The stuff is crazy strong.
Tags |
making your own spur, melting metal |
Is it possible to mold your own gears? - Similar Threads | ||||
Voodoo mold information | crawl-o-matic | Tires and Wheels | 5 | 05-20-2013 09:25 PM |
Voodoo Mold is DONE | crawl-o-matic | General Crawlers | 37 | 04-03-2013 01:51 PM |
Thermoform mold making | Deerhurst | Chit Chat | 5 | 05-09-2012 10:17 AM |
Breaking the mold!!! A super in Utah!!! | Chaotic Crawlers | Superclass Crawlers | 46 | 10-17-2011 05:50 PM |
Anybody deal with house mold ? | camobob | Chit Chat | 19 | 03-10-2011 11:19 PM |
