10-24-2006, 06:36 AM | #1 |
Newbie Join Date: Jul 2005 Location: bel air md
| newb: jeep troubles = whining sound
hey, im having some troubles with my nylint, each time i try to climb something all it does is whine. no wheels move and it takes like 5 tryed just to get over a little rock? usually it just climbs right over but something is wrong. anyone else have this problem or a fix? thanks erik |
10-24-2006, 06:48 AM | #2 |
Pebble Pounder Join Date: Sep 2006 Location: Hardin
sounds like your belts are slipping, pull the axles apart and clean the belts....i usually use rubbing alcohol on a q-tip if i am just doing a quick cleanup.... you can also take some sandpaper and sand the small pulley to take the smooth finish off of it so the belt wont slip as bad.... some people run smaller belts, in my experience, all that does is causes broken parts... |
10-24-2006, 10:02 AM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
i've only messed up one set of gears with tighter belts, and that was from grass getting wrapped around the tire and me just pushing it on. and like someone else here said, coke on the belt works good too. -Dalton |
