12-16-2013, 11:17 AM | #21 |
Newbie Join Date: Dec 2013 Location: Palmer
| Re: Unique Project - Need Help and Advice
Yeah, that is kinda of the direction I am thinking of going. For comparison purposes, what size tires does the mad torque come with stock? Or does 1/8th scale "generally" mean 2.2" tires? I looked but didn't seen anything definite. I saw something that said 2.8 but that didn't seem right?? Thanks.
12-16-2013, 12:37 PM | #22 |
Saw some vids of the bizzard running around in snow that looked pretty impressive. I would think it would work really well for my application but I didn't see anything about how it would do in mud. I don't need anything really fast, in fact I think speed would do a lot more harm than good, and hence the reason I gravitated towards the crawlers. Need to find a forum/thread with some blizzard users to see how they deal with mud or what it takes to get them to deal with mud. The only only issue I see with the blizzard would be it seems a little small?? But maybe not. PV |
12-16-2013, 01:12 PM | #23 | |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Re: Unique Project - Need Help and Advice Quote:
12-17-2013, 01:02 PM | #24 |
So something else to consider is durability. This will be used for work, in the mud, for 2-4 hours twice a year. Obviously if I go with a "cheap" rig, such as the Mad Torque, breaking parts every 30 minutes will defeat the purpose. The area to fairly flat and all mud and we only need to collected data on a 25 foot grid so it will be traveling is mostly straight lines back and forth to the beach. What parts will I need to look at upgrading? My guess would be steering servo, axles, and linkages??? I've seen vids of rigs going through some pretty wet/muddy areas but how "water proof" will it be out of the box? We won't be in water and will be keeping the mud slinging to as little as possible b/c of the GPS receiver but getting muddy will be unavoidable. Thoughts? PV |
12-17-2013, 04:11 PM | #25 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
You can plastidip the rig electronics and maybe build a plexi box for the gps receiver.
12-17-2013, 04:27 PM | #26 |
Rock Crawler Join Date: Jul 2005 Location: Playing with toys with my son's
I have used balloons to water proof stuff for years. Put whatever in the balloon zip tie the opening easy to clean off and if you have to get at it to fix somthing or work on it just cut it off and put another one on. There cheep and come in all sizes.
12-17-2013, 04:39 PM | #27 |
Thanks for the thoughts, both great ideas. PV |
12-17-2013, 05:07 PM | #28 |
Quarry Creeper Join Date: Jan 2013 Location: Benicia/Vallejo
Like I posted earlier. Dlux makes axle upgrades and the electronics are probably adequate for your purpose. I think the first thing to fail will be the servo horn and servo. You can get cheap upgrades there. The truck is on sale for $167 1/8Th Mad Torque Rock Crawler Ready to Run (Blue) Check out this build thread, there's lots of good info in there: Mad torque build, cheap and easy |
12-17-2013, 10:48 PM | #29 |
Sorry missed your earlier comments. Thanks for the info and especially the build thread. PV |
12-17-2013, 11:18 PM | #30 |
So looking around, the Max Stone 8 looks to be in the same ball park as the Max Torque? Found it for about $200 Similar quality and durability?? Or is one significantly better than the other. Just looking for a basis of comparison. Thanks. PV |
12-18-2013, 01:27 AM | #31 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
Just a thought; would this be easier to pull off if the unit was mounted on a trailer? Go the 1/8 scale but have it pull a trailer just big enough to haul the unit (using the kong tires on the trailer too)
12-18-2013, 08:39 AM | #32 |
Trailera tend to get in to trouble when you have to back up.
12-18-2013, 02:40 PM | #33 |
I had thought about a trailer setup after seeing a couple of them in videos but I think it would cause more issues that it would be worth. For example the backing up thing. I think a 1/8th with some kong tires will be the best option price wise to try it out. Now just need to decide on what rig to go with... PV |
12-22-2013, 09:02 PM | #34 |
Quarry Creeper Join Date: Feb 2013 Location: Northcentral Wisconsin
um, wouldnt an airboat kind of thing work better for the OPs purposes? wide, flat bottom boat - propeller style propulsion. Not to take anything away from all the interesting ideas - but to my mind this gps "project" needs an air boat - the right tool for the job and all that. |
12-24-2013, 05:36 PM | #35 |
I had considered and airboat but was concerned the size I would need would be limited to a nitro motor and short run times? I'm afraid it would also be significantly more expensive? Plus I like the idea of the simplicity of an electric setup. But if I'm mistaken, I'd be all for checking into it more. PV |
12-24-2013, 11:01 PM | #36 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
I've got a used blizzard that is collecting dust if you want to go that route.
12-25-2013, 12:07 AM | #37 | |
The Mad torque has parts that are interchangeable with axial and there's aftermarket upgrades available if you break it. Another option would be a used RC4WD super bully if you could find a used one in your price range. | |
12-25-2013, 06:38 AM | #38 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
Awesome thread! Subcribed! I think anything with tracks would get mud and junk stuck in the tracks too much, tons of maintenance with all the moving parts. I would suggest something with huge paddles and horsepower, but thats probably going to be very expensive. I would also consider the emaxx, its pretty big, two speeds and comes with tractor like tires. |
12-25-2013, 11:44 AM | #39 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
I saw the picture of what you are trying to haul, but what is the overall size and weight? Another vehicle to consider is the traxxas summit and run jumbo kongs as others have suggested. Would a quad copter work if you had special landing gear that would make it float?
12-25-2013, 11:48 AM | #40 |
Rock Crawler Join Date: Oct 2012 Location: Casper
I believe he said it has to stay the same elevation, relative to the ground it's on. Sounds like he's trying to get a precise topographic/3D map.
Unique Project - Need Help and Advice - Similar Threads | ||||
New crawler project? Need advice | fgt | General Scale Talk | 3 | 08-12-2013 01:00 PM |
1.5 scale project need advice | Canadiancoffin | 1.5 Scale Rigs | 3 | 01-03-2013 10:55 PM |
Any advice for my project? | tylerlong | Non Crawler RC's | 6 | 03-17-2010 02:15 PM |
unique 1:1 crawlers / project ideas.... | STANG KILLA SS | Chit Chat | 4 | 10-14-2008 09:31 PM |
