12-17-2013, 02:45 PM | #1 |
Busy buildin or crawlin!! Join Date: Aug 2007 Location: Castle Rock
| Transmission Difference
I'm about to buy a transmission for my custom scaler and was just wondering what is the difference between the Wraith tranny and the SCX tanny? I notice the Wraith has a bigger housing. Any help is appreciated. Thanks |
12-17-2013, 02:52 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
| Re: Transmission Difference
Wraith has a longer output on the rear to help clear the longer Wraith skid plate.
12-18-2013, 06:36 PM | #3 |
The only physical differences between the two are the plastic case halves, and the output shaft halves. The Wraith housing has "extra" room inside for a dig unit, as well as a 3rd, very oversized, output shaft bearing. The SCX trans is normally mounted with the motors endbell facing forwards, the Wraith's is normally mounted with the endbell facing rearward. |
12-18-2013, 07:34 PM | #4 |
Pebble Pounder Join Date: Jan 2009 Location: Yacolt, wa
look up rc4wd's ax-2 tranny
12-19-2013, 03:45 PM | #5 | |
| Re: Transmission Difference Quote:
12-19-2013, 03:53 PM | #6 |
| Re: Transmission Difference Yes, they have the same mounting holes. The big challenge is getting the drive shaft angles right so that you don't bind due to the longer output on the Wraith transmission. The dig option can be made to work on a SCX-10 too.
Transmission Difference - Similar Threads | ||||
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. | Tomy | Axles, Trannys, T-case | 4 | 01-20-2013 07:48 AM |
Axizl Transmission VS Wheely King Transmission | Tonelock | HPI Wheely King | 13 | 09-03-2008 12:39 PM |
