Thread: Connect trans to t-case output?
Old 01-03-2014, 09:08 PM   #1
Default Connect trans to t-case output?
I struggled with a search on this topic so please forgive me if this common knowledge. I don't have any parts yet but I would like to connect a Disruptor planetary trans to a Triton T-case by way of the front output shaft. Of course I would then connect the front axle to what is the typical input shaft instead.
Does anyone see why this cannot be done? It is 1:1 ratio.
Sidenote: If you were able to connect in this fashion could you not also over-gear the front axle with the Hammer 1.47:1 for ledge climbs?
Thanks for any "input"
Creep is offline   Reply With Quote
Old 01-03-2014, 10:36 PM   #2
Default Re: Connect trans to t-case output?
Not sure on the secondary gearing question, but I run a killer case (1:1) and have it set up opposite like your asking. I did it for clearance issues and it runs no problem. You may have to flip the rear axle depending on your gear setup, because it would technically be spinning in the opposite direction it normally would. But otherwise no issues or problems.
Side note Im Running an R3 trans w/ killer trade and Yota axles w helical gears..
--Dan
sickcivic95 is offline   Reply With Quote
Old 01-04-2014, 12:12 AM   #3
Awesome. Thanks for the info. I'm not sure I would need to flip the axle but I plan to run K44's & actually was wondering if I could flip the rear axle for a link mount idea I have! Twofer! Maybe...
Old 01-04-2014, 01:12 AM   #4
You planning on running the axle over the leafs to Lower the stance?? And if so, yes its doable......
--Dan
Old 01-04-2014, 01:16 PM   #5
Actually, I am thinking if the spring perches were underneath the axle I could use that to my advantage in making scale-looking lower link & shock mounts. Plus the truss would terminate more cleanly into the axle tube. That's why I want to use the output shaft as an input - just for that extra touch. Almost ready to buy some parts...
Connect trans to t-case output? - Similar Threads
Can I replace the dig trans case with a regular case? redsawacs Axial Wraith 4 05-28-2013 09:16 AM
VP AX10 tranny case in a Wraith - rear output shaft 2-shot Axial Wraith 9 07-29-2012 07:04 PM
trans output LEROY Axial Wraith 3 07-02-2011 05:33 AM
Axial Trans output shafts Gozer Axial AX-10 Scorpion 12 04-06-2009 01:02 PM
single output trans for use with t-case??? jetboat General Scale Talk 39 11-08-2008 12:15 PM
