G6 kit front suspension issue? So I am putting together my new G6 kit and I have a problem, the servo hits the chassis cross member right at full droop, so I have zero up travel, just wondering if anyone else had this issue? I'm glad I bought it from rpp and they included a free lift kit. |
Re: G6 kit front suspension issue? The battery plate mount cross member? |
Re: G6 kit front suspension issue? Lol yep, I figured it out, you shouldn't build kits while taking care of two small children, you end up putting things in backwards lol. |
Re: G6 kit front suspension issue? I was kind worried about the brace hitting my servo too but it had 2-3mm of space between the two. Just enough to fully articulate and droop. |
Re: G6 kit front suspension issue? I'm using a SAVOC servo, and it hits the battery mount cross member, without a servo horn on the servo. Think all I got to do is move servo back with different mounts. |
Re: G6 kit front suspension issue? It is pretty normal to have to clearance the crossmember in front of the servo. Also typical to have to lightly clearance the inner part of the front shock tower crossmember to clear the servo mounts when fully articulated. |
