03-13-2014, 11:05 AM | #41 |
Pebble Pounder Join Date: Nov 2013 Location: Here
| Re: Maxstone 10 budget build
I would be worried about how much of that body you have to chop up to avoid too much wheel rub with 2.2's. It looks much better than the stock body, of course that doesn't take much to get better than the stocker. On my MaxStone10 I took the 17mm Hexes and 6.3" diameter tires off my 1/8 Mad Torque and slapped them on my Max Stone 10 and it crawls at least 100% better with just the big tire change and wider stance. With the long wheelbase of the MS10, the big 6.3's keep it from high centering as much and it has greatly expanded the obstacles I can climb over now. I still need to get a handle on the torque twist and get the CoG lower.
03-13-2014, 05:04 PM | #42 | |
Rock Stacker Join Date: Jan 2012 Location: Columbia, MO
| Re: Maxstone 10 budget build Quote:
03-13-2014, 09:26 PM | #43 | |
Swapped Knuckles and axle shafts between my Max Stone 10 and my Mad Torque because I needed 12mm Hexes on my mad torque for a scale build I was doing. All the parts bolted right up together. Width with the setup is about 1" wider than stock. Last edited by DeoreDX; 03-13-2014 at 09:33 PM. | |
03-13-2014, 10:10 PM | #44 |
Sure does look like a monster truck. |
03-15-2014, 07:25 PM | #45 |
So no issues fitting Axial shafts into the max stone? The stock shafts have a short side and long side. About 1/4" (6mm) difference. The Axial shafts are both the same length. I snapped an axle and stripped the locker. If I get the axial locker diff case locker and dogbones I can just bolt everything right up? Last edited by DeoreDX; 03-16-2014 at 07:02 AM. |
03-16-2014, 10:41 PM | #46 | |
06-30-2014, 06:11 PM | #47 |
Newbie Join Date: Jan 2014 Location: USA
So all that is needed is the drivecups and steel lockers? and its a decent crawler? I plan to keep it stock for a while - them cups n lockers taking off bumpers n standoffs for em and mod or compleatly take out wheel foams lower cg best I can, mess with shocks for torque roll. Does it handle 3s stock? if I find the motor is too weak, I may go buy a little $15 axial 540 can my crawling areas will be bricks mud weeds road... Edit: I was also wondering if the axles could go together with eachother, to have 2 axels coming out to say make a 6x6 or something. Last edited by Higgins909; 06-30-2014 at 06:19 PM. |
07-03-2014, 09:03 PM | #48 |
Rock Stacker Join Date: Feb 2014 Location: Irmo, SC
The motor is NOT weak. It is very powerful, just very slow. It's also very accurate at low speeds. I can't do the low speeds stuff near as well with my Wraith and it's 20T motor. I am thinking of trying a 35T in my maxstone.
07-04-2014, 07:47 PM | #49 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
You guys must be lucky cause my neighbor bought a 1/10 maxstone and the entire thing fell apart in one week. My scx10 dominated it everywhere and every way. But his did not have upgrades, it was all stock. I have to say, that thing was exceed crap...no offense to anyone.
07-08-2014, 10:11 PM | #50 | |
07-09-2014, 01:12 AM | #51 |
Rock Crawler Join Date: Jan 2013 Location: Australia
cool, looks different (in a bad ass way)
07-09-2014, 04:03 PM | #52 | |
07-10-2014, 09:17 PM | #53 | |
Quarry Creeper Join Date: Jun 2014 Location: 36oly
Anyway I like what you've done so far. | |
07-11-2014, 11:54 AM | #54 |
| Re: Maxstone 10 budget build |
07-11-2014, 11:56 AM | #55 |
07-11-2014, 11:58 AM | #56 |
| Re: Maxstone 10 budget build Yeah I like to bash on exceed, you're right about that. I just don't see the point in wasting money on these. Look at all of you guys, putting axial parts in it just to make it work!? Why not just buy an axial..
07-11-2014, 02:09 PM | #57 |
| I wouldn't pay that much for all the cheap plastic parts axial comes with. I could make a better crawler for less out of an exceed base.
07-11-2014, 02:18 PM | #58 |
| Re: Maxstone 10 budget build A MS10 is $140 + axial drive cups and steel lockers $20 is $160 and a axial is like $300
07-11-2014, 02:19 PM | #59 |
Quarry Creeper Join Date: Nov 2013 Location: canada
keeping an eye on ur build. Maxstone 10 custom build is on my menu. it will be my first shafty |
08-18-2014, 12:33 AM | #60 |
Rock Stacker Join Date: Jul 2014 Location: Littleton
Keep us informed of your progress, don't let the Exceed haters get you down.
Maxstone 10 budget build - Similar Threads | ||||
My daughter's trial truck build- Maxstone 16/Little tikes cabover | 89redranger | Losi Mini-Rock Crawler | 9 | 11-20-2013 09:25 AM |
MaxStone 1/8th build | Triple88a | Superclass Crawlers | 1 | 02-10-2013 08:51 AM |
best budget build??? please help | drilldeep | General Crawlers | 3 | 06-17-2009 08:19 AM |
this budget build ok? | Bknight | Newbie General | 10 | 04-09-2006 10:29 AM |
