02-15-2014, 03:15 PM | #1 |
Rock Crawler Join Date: Jan 2013 Location: Australia
| Vanquish Products knuckles axles chubs lockouts
Hi, i was basically wanting to know what the best options were if i was wanting to go vanguish products axles, knuckles, lockouts and chubs. Will i be able to get these for my scx10 without modifying anything or any other new parts? Also as another option which im pretty sure would work, would be the aluminum chubs lockouts and knuckles from axial and just keep the stock axles. any ideas? Cheers, Hammer Last edited by Hammer!; 02-15-2014 at 03:33 PM. |
02-15-2014, 04:07 PM | #2 |
| Re: Vanquish Products knuckles axles chubs lockouts
I haven't been impressed with axial C hubs and knuckles. I much prefer VP's parts since they are a better design than the factory stuff not just an alloy copy. Personally I always recommend doing the XR conversion and using VP's parts with axial universal shafts. Saves some money, allows for more steering and adds just a bit of width to the axle so the tires clear the links and shocks. |
02-15-2014, 05:17 PM | #3 |
thanks just wondering would the axial parts fit in without any mods?
02-15-2014, 05:29 PM | #4 | |
| Re: Vanquish Products knuckles axles chubs lockouts Quote:
How to do the narrow XR10 mod to Axial axles | |
02-15-2014, 06:28 PM | #5 |
the aluminum lockouts knuckles and chubs although ill have another look at the xr mod
02-15-2014, 06:35 PM | #6 |
Don't waste your money on axial parts. They are the same cash as VP and not as good in my opinion. VP offeres 8* knuckles and C hubs but axial doesn't and VP has tighter tolerances than axial in my experience. Axial stuff feels and looks just like STRC or Hot Racing yet costs twice as much as they do.
02-15-2014, 07:03 PM | #7 |
i know but if i were to install the 8* knuckles and the chubs and lockouts from vp what else would i have to change? what steering links would i need?
02-15-2014, 07:06 PM | #8 |
and also just wondering would i have to get the straight axle if i got the axial rear lockouts or is that only for the ax10
02-15-2014, 07:21 PM | #9 | |
What? I'm not following you. Last edited by WHITE-TRASH; 02-15-2014 at 07:23 PM. | |
02-15-2014, 07:52 PM | #10 | |
it says o the part description for the axial rear lockouts that it requires the straight axial but i wasnt sure whether that applies to the scx10 or the ax10 as the rear lockouts are designed for both. | |
02-15-2014, 08:18 PM | #11 |
| Re: Vanquish Products knuckles axles chubs lockouts Yea probably just a bit longer, I'd imagine around 1/2" or so. Ok now I'm following you. On the first generation ax10's they had dog bone and cup axles just like the front and a different style of lock out. If you were converting from the old style to normal lock outs you needed to get a set of what are now standard issue straight axles. You won't need to buy anything extra. |
02-15-2014, 09:17 PM | #12 |
ok, thanks for your help its greatly appreciated
Vanquish Products knuckles axles chubs lockouts - Similar Threads | ||||
Vanquish axles with Axial chubs n knuckles tie rod... | o0wiz0o | Axial SCX-10 | 2 | 04-07-2013 10:44 PM |
