03-03-2014, 06:35 PM | #1 |
Rock Stacker Join Date: Dec 2012 Location: rochester
| drive shaft options
Does anyone have any recomondations for a drive shaft that can handle a fairly sharp angle without binding? I have a wroncho that the stock wild boars just twist something fierce. Ive tried some cheap set ( dont remember brand) that suck. Thanks.
03-04-2014, 06:45 AM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: drive shaft options
the MIP's have a decent angle BUT you can still get so much of an angle. try clocking your axles some to help a little
03-04-2014, 08:23 AM | #3 |
Rock Crawler Join Date: May 2012 Location: Columbus
clock axles or JUNFAC has great axles for the price an do harp angles thats what i use
03-04-2014, 11:31 AM | #4 |
Cool. Thanks. Ill check em out.
03-04-2014, 11:58 AM | #5 |
Rock Crawler Join Date: Dec 2012 Location: Utah
THESE ARE PRETTY COOL NOT SURE ON STRENGTH YET THOUGH HAVENT HAD A CHANCE TO RUN THEM YET, ILL REPORT BACK SOON PROPPELER SHAFT (5mm to 5mm) - Scale Designs International |
03-04-2014, 03:50 PM | #6 | |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
| Re: drive shaft options Quote:
03-04-2014, 09:55 PM | #7 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
He is right, your gonna push your tranny right off its screws! Lol. Made my day!
03-05-2014, 07:53 AM | #8 |
| Re: drive shaft options Universal Shaft : JunFac.com Punisher Shaft ahh how did i forget RPP try them too an as for MIPS there good but for the price no, i can buy 3 junfacs for the price of 1 MIP Last edited by Ohioskills; 03-05-2014 at 08:02 AM. |
03-05-2014, 09:32 AM | #9 | ||
03-05-2014, 09:52 AM | #10 |
| Re: drive shaft options Actually if you look at how they are assembled they do have travel and if you guys look in the ax10 sportsman section there a lot of guys using them on their ultra light sportsman shafty builds!!!
03-05-2014, 10:09 AM | #11 |
| Re: drive shaft options 8mm or roughly just over 3/10". Not much at all. I saw 2-3 builds running them. I'd stick with MIP for sure |
03-05-2014, 04:01 PM | #12 | |||
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
If you guys build your trucks properly, with good geometry and suspension travel, you shouldn't need more than 8mm of slip on the drive lines... | |||
03-05-2014, 05:01 PM | #13 |
Everyone is ignoring the real problem. Every single driveshaft joint is going to wear out prematurely if run at steep operating angles. Sounds like you need to either lower the rig, flip the trans, or limit downtravel to save wear and tear on your driveshafts. I've run both the Junfacs, and the MIP's. The Junfacs are IMO, junk. The pin in the joint is much smaller than the MIP, it uses dinky 3mm setscrews compared to the MIP's 4mm, the slip section is a D shape, which binds horribly under torque (which kills pinion and trans output bearings), compared the the MIP's precise multi-spline slip section. Spend your money once and get the MIP's. The only disadvantage to the MIP's is weight. They are probably the heaviest driveshaft option out there. If you need strong and light then look at using plastic Traxxas Revo shafts with the end yokes drilled out to fit cut down Axial steel yokes (search Maxx Shafts Made Easy). I'm using this mod on a go-slow no-slipper-clutch AX-10 and so far the only bummer is that you basically have to put a dot of superglue on the miniature E-clip that holds the pin in the U-joint. Otherwise it seems like every time you wack the yoke on a rock the E-clip pops off and ends your day. |
drive shaft options - Similar Threads | ||||
so many drive shaft options? | steveo 561 | Axial SCX-10 | 2 | 05-16-2012 08:01 PM |
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
Drive shaft options tips | toy4crawlin | 1.9 Scale Rigs | 7 | 01-08-2011 10:06 PM |
wk drive shaft options | Burge | HPI Wheely King | 11 | 06-04-2008 03:25 PM |
drive shaft options????? | rcjeepbuilder | HPI Wheely King | 14 | 02-01-2008 03:11 PM |
