03-26-2014, 06:20 PM | #1 |
Pebble Pounder Join Date: Nov 2013 Location: Bedford, Nova Scotia, Canada
| Axial Ti-Nitride shafts in G-Transitions?
I bought a CR-01 roller recently with G-Transitions on it. The shafts are definitely scratched up, although I wouldn't say gouged, and the shocks don't seem to be leaking.... However, I want to go to Ti-Nitride coated shafts to avoid scratches, etc. in the future. The G-Transitions have 3.5mm shock shafts. I don't think G-Made has TiN shafts for them, so I was wondering if anyone has tried the 3.5 mm Axial Ti Nitride coated shafts (for the AX30092 shocks, not the stock SCX10 ones) as a replacement? Part numbers are (for different shaft lengths) AX30147, AX30146, AX30155. In theory they should work, as they are the same diameter - but theory and reality do not always match. Anyone tried this or have alternate suggestions? Thanks! |
03-28-2014, 09:15 PM | #2 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
| Re: Axial Ti-Nitride shafts in G-Transitions?
[QUOTE=GraciousOne;4723520]I bought a CR-01 roller recently with G-Transitions on it. The shafts are definitely scratched up, although I wouldn't say gouged, and the shocks don't seem to be leaking.... QUOTE] you have used g-made shocks that don't leak? that's a 1st as long as the diameter for seals and pistons can work together i'm sure you can make em work. |
03-30-2014, 03:58 PM | #3 |
Well, I admit that I haven't had it on the trail yet. So all I can say for sure is that it doesn't leak while sitting in a shelf or while being pumped by hand. Of course, that alone makes them better than any axial shocks ever made. ;)
Axial Ti-Nitride shafts in G-Transitions? - Similar Threads | ||||
Losi Ti Nitride Steering King Pins | JEG | Team Losi Comp Crawler | 7 | 01-31-2011 07:33 PM |
anyone ever experience cauterizing by silver nitride? | dieselfuel | Chit Chat | 24 | 07-20-2008 02:59 PM |
Integy TI-NITRIDE Hex Driver 7pc Tool Set | dezfan | Tools, and Procedures | 11 | 02-17-2007 07:36 PM |
