03-30-2014, 07:49 AM | #1 |
Rock Stacker Join Date: Jan 2013 Location: Fort Drum
| Building indoor course
So I'm in Afghaistan, and have a ridiculous amount of spare time on my hands due to the whole draw down thing. I brought my scaler with me, and have a Losi MRC Pro on the way to use while I work on the scaler. The base I'm at is pretty flat, and our compound doesn't have a whole lot of rocks so I had to find a way to get my fix. Did a bunch of research on here on course, and came up with a plan. We have a lot of scrap plywood laying around, so I ordered up a roll of chicken wire and a roll of burlap (Thanks Ebay haha). Also we have a pallet of concrete mix here in the compound doing nothing. Started today, got a majority of the framing completed. It is two sections, each being 46" by 25". It's sized to fit under my desk/workstation in my room. The far right will be a rock garden style area. To the left of that will be a peak climb on the closest side, and a v-notch on the far side. Then to the left is a steep ledge climb on the closest, and a stepped ledge style climb on the far side. I know usually people add sand to portland cement to get the mix right, but I am hoping I can use straight mixed concrete for it with no issues, as that's all I have access to. |
03-30-2014, 08:20 AM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: Building indoor course
Got any sand blasting cabinets around? My buddy utilized used blasting sand for one he made.
03-30-2014, 10:27 AM | #3 |
I'm thinking the sand is just for texture. To that end, could just drag a broom across the concrete while its still fresh, and groove the surface. If the mix is kinda runny, and you're feeling particularly maniacal, you could use either a gloved hand, piece of plywood, whatever, and 'pat' the surface. That should raise up some peaks and give a fairly aggressive texture if done right. Might need to mix up a small batch (just a couple of cups) and try out your techniques. See what works for you. |
03-30-2014, 12:24 PM | #4 |
Rock Stacker Join Date: Mar 2014 Location: Siskiyou County
Pure cement will crack to pieces,you need sand with the portland to bind it together,preferably sharp sand not beach sand. Sift some from the yard to mix in.. edit:mix 1 part portland to 2 parts sand for added strength. Last edited by 4.3 Zook; 03-30-2014 at 12:32 PM. |
03-30-2014, 12:52 PM | #5 |
Now I understand that pure cement is week due to a lack of binding agent, but do you think the concrete I have will work? It already has sand and small gravel (aggregate) mixed into it.
03-30-2014, 12:58 PM | #6 |
Sorry I misunderstood,yeah the premix will work,if the aggregate is too large you could sift it out.
03-30-2014, 01:15 PM | #7 |
| Re: Building indoor course |
Building indoor course - Similar Threads | ||||
MiRCa indoor course building at Larry's 12/5/10 | Farmer | Michigan | 6 | 12-14-2010 02:33 PM |
Building indoor course! | dflynt | General Crawlers | 0 | 08-18-2010 12:31 AM |
Building an indoor coarse ? | beni | Chit Chat | 1 | 12-07-2008 09:54 PM |
Building an Indoor Course | Bullfrog | General Crawlers | 7 | 09-10-2008 06:23 PM |
Building an Indoor course | RichieOTR | General Crawlers | 9 | 05-22-2007 07:11 AM |
